Hondata studder
Old Apr 11, 2002 | 06:31 PM
  #26
dustin's Avatar
Default Re: Hondata studder (HXMan)
Yeah he also has a disassembled car that doesn't run =P
Old Apr 11, 2002 | 07:45 PM
  #27
ILOVEGIRLS's Avatar
Default Re: Hondata studder (dustin)
moving it up to the top cause ill be getting the hondata too.
Old Apr 11, 2002 | 08:40 PM
  #28
HXMan's Avatar
Doh'!
Old Apr 11, 2002 | 08:44 PM
  #29
RMS's Avatar
RMS
Default Re: Hondata studder (ILOVEGIRLS)
I doubt you're going to find a bug. More likely a tune problem on the fuel map. We've done a couple dozen installs/tunes (using Horiba wide band O2) without a single similar issue. Does it occure immediately after a reset of the ecu?...if the rest of the map is out to lunch might the trim be causing it, Doug?
Old Apr 11, 2002 | 08:52 PM
  #30
HybridPsi's Avatar
HX Man...I'm in Brewtown. I have a 5G w/ B16 and FMAX kit. I'm looking to get Hondata and I wanted to talk to you. Could you hit me up with an email. hybridpsi@wi.rr.com.
Marc
Old Apr 11, 2002 | 09:57 PM
  #31
Hondata's Avatar
Default Re: Hondata studder (Del...'luded)
A possible cause for the problem could be that the part throttle fuel maps are way out. In closed loop the ECU could be trimming (or adding fuel) to compensate. In open loop this does not happen which is why the problem seems to be less common in open loop.
If you are datalogging, looking at the short term and long adjustment while in closed loop tells you how much the ECU is adjusting the fuel - which is why we need datalogs.
Full throttle tuning is great, but part throttle tuning is essential and that can be done best with a wideband on the street.
Doug
Old Apr 12, 2002 | 07:41 AM
  #32
HXMan's Avatar
Default Re: Hondata studder (HybridPsi)
I sent you an email marc.
Old Apr 12, 2002 | 07:48 AM
  #33
blowncivichb's Avatar
Guys...think we could keep the topic on topic?
Old Apr 12, 2002 | 08:57 AM
  #34
Xerxes's Avatar
New User
Default Re: Hondata studder (Hondata)
I'm thinking that this could have something to do with what point your ecu switches over from closed loop to open. All of you with stage4 should open up romeditor and find out what level of vacuum the ecu switches to open-loop.
Even with the base map that came with my hondata, i have never experienced this problem
-Xerxes
Old Apr 12, 2002 | 06:22 PM
  #35
HXMan's Avatar
Default Re: Hondata studder (blowncivichb)
Oh jeeze, sorry! It was about hondata at least.
Old Apr 13, 2002 | 07:31 AM
  #36
93LSivic's Avatar
Ok, I just installed my 3B. Im having the same issue I think. Seems to be right around 3500 RPM though. If I am driving and let off the gas the slightest bit then give it a little gas again it seems to have a little hickup. WTF??
It'll do it around 2500 sometimes too? Hopefully when I have it dyno'd it will get rid of this problem.
Old Apr 13, 2002 | 10:28 PM
  #37
lucas569's Avatar
Default Re: Hondata studder (93LSivic)
same here! but im still running around on the base map,so who knows. seems to happen around 2800 rpm. stage 2b w/ rc 440 cc injectors p-72 ecu.
Old Apr 14, 2002 | 01:03 AM
  #38
Trigun's Avatar
Default Re: Hondata studder (lucas569)
before i read this thread, i did not really notice anything during highway cruising or normal city driving but now, i 'think' there is a SLIGHT studder under 4k rpm
doesn't feel as pronounced as the way some of you describe it but again, i 'think' there is a very very very slight studder, almost impossible to notice unless i told you about it.
not really bothersome and sometimes i don't even notice it unless i'm trying to.
[Modified by Trigun, 2:05 AM 4/14/2002]
Old Apr 14, 2002 | 09:06 PM
  #39
SIK IN DA HED's Avatar
New User
Default Re: Hondata studder (Trigun)
so have you guys figured out the problem to the studders?
Old Oct 6, 2003 | 08:58 PM
  #40
project dc2's Avatar
Default Re: Hondata studder (SIK IN DA HED)
up to the top .. hahaha old post but hey it happend to me !!!
Old Oct 6, 2003 | 11:22 PM
  #41
accordfreak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trigun &raquo;</TD></TR><TR><TD CLASS="quote">before i read this thread, i did not really notice anything during highway cruising or normal city driving but now, i 'think' there is a SLIGHT studder under 4k rpm
[Modified by Trigun, 2:05 AM 4/14/2002]</TD></TR></TABLE>
wow same exact place as mine!.. i just noticed it yesterday after having the hondata for a few months already....
Old Oct 7, 2003 | 12:17 AM
  #42
DLOTYPER's Avatar
interesting here, i run a 2b setup on my 93 si hatch/turbo gsr,, 550cc injectors, msd 6al,,,,, the funny thing here is that when i put a msd in my **** i got the hiccup at around 79-80 mph and around 3500 rpm's Boosted-hybrid tuned me up and he could not figure out that blip,, when i ran the stock honda distributor,, it went away, i believe it has something to do with the msd if you guys are running that,,,,,, i dont know let me know about that,,,,,,
Old Oct 7, 2003 | 12:58 AM
  #43
JDEM1's Avatar
Default Re: (DLOTYPER)
i dont have msd and i have the problem in every gear at around the same rpm, partial throttle around 3200 or so... if you look around.. theres a HUGE thread about HONDATA HESITATION.. you didn't have to bring this ancient thread back to life...
Old Oct 7, 2003 | 05:12 AM
  #44
symba's Avatar
Default Re: (JDEM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDEM1 &raquo;</TD></TR><TR><TD CLASS="quote">... if you look around.. theres a HUGE thread about HONDATA HESITATION.. you didn't have to bring this ancient thread back to life... </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=550794
1SlowSi
Jun 9, 2005 02:38 AM
JDEM1
Feb 1, 2005 11:30 AM
legendboy
Oct 3, 2003 09:24 AM
crx1856
Sep 7, 2003 12:44 AM
lePetitePrince
Aug 1, 2003 08:51 AM
