Weird Hondata Problem
Old Sep 29, 2003 | 05:55 PM
legendboy's Avatar
Default Weird Hondata Problem
Lately when boosting It feels like I'm getting a boost cut or something. But at low boost, say 2 psi or so, only when its building boost. I get cel flash and then nothing. Not sure what it is, boost cut is disabled in hondata. Sometimes is fine sometimes it does it. Any ideas?
Old Sep 29, 2003 | 05:58 PM
LiLOtaku's Avatar
Default Re: Weird Hondata Problem (legendboy)
have you looked at your fuel/timing maps to see if there are any odd anamolies?
Or did this just suddenly occur with the same map you've been using for a while?
Old Sep 30, 2003 | 06:04 AM
legendboy's Avatar
Default Re: Weird Hondata Problem (LiLOtaku)
just started out of the blue
Old Sep 30, 2003 | 08:15 AM
shermanyang's Avatar
hey i had the same problem and it turned out to be a loose spark plug wire!! check your wiring to see if it's your ignition first. also check to see if the led on your hondata blinks when engaging boost. hope that helps.
Old Oct 3, 2003 | 08:53 AM
legendboy's Avatar
Default Re: Weird Hondata Problem (shermanyang)
ttt
Old Oct 3, 2003 | 09:24 AM
Double121's Avatar
That happened to me when my wastegate line came loose and boosted to 20psi. Thank god for hondata. It saved my butt. Maybe your hondata we screwy. I would unplug everything and plug it all back in and see if it resets.
1.8turbolsvtec
Apr 25, 2004 03:59 AM
