Hondata solenoids
Old Feb 23, 2008 | 07:27 PM
94turboeg's Avatar
Default Hondata solenoids
Anyone use these yet?
Old Feb 23, 2008 | 07:33 PM
boosted hybrid's Avatar
Default Re: Hondata solenoids (94turboeg)
Its a mac valve, and looks identical to what AEM sells. We use AEM boost solenoids all the time with hondata boost control, works much better than the gm solenoids.
Old Feb 23, 2008 | 07:52 PM
Turbo-charged's Avatar
Default Re: Hondata solenoids (boosted hybrid)
if it is the same as the AEM ones, which im sure it is, they work great.
i dont like using the GM solenoids. they just seem ghetto, you can only use ghetto hose, and its a normally open solenoid so if anything goes wrong, the boost will skyrocket.
Old Feb 24, 2008 | 05:57 AM
92HB_HB's Avatar
Default Re: Hondata solenoids (Turbo-charged)
i remember trying to buy that valve from an industrial distributor here locally, and they wouldn't let me buy it for LIABILITY REASONS because I was an individual and not a business, and because I was using it on my car..
BUT yet you can easily buy a GUN and shoot up a school..
Figure that out..
Old Feb 24, 2008 | 05:59 AM
Joseph Davis's Avatar
Everything you see in the aftermarket at a two and a half to four times markup is going to be a rebadged MAC, Delco, or Humphrey unit.
I won't list STC as they are chinese as hell and I've been able to get zero feedback on build quality and reliability from idustrial sources, but they have the higher temp rated F-class coil at Humphrey prices. Also, I haven't seen them offered in the aftermarket... but now that I have mentioned them I am sure that I will shortly.
Old Feb 24, 2008 | 09:05 AM
mrbsponge's Avatar
whats the price on one of the "hondata" solinoids?
Old Feb 24, 2008 | 09:55 AM
Ramma's Avatar
Default Re: (mrbsponge)
$100
Old Feb 24, 2008 | 10:36 AM
*Boostwerks*'s Avatar
Default Re: Hondata solenoids (Joseph Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">Everything you see in the aftermarket at a two and a half to four times markup is going to be a rebadged MAC, Delco, or Humphrey unit.
Would you happen to know where I can get one of those MAC valves?
Modified by Boostwerks.com at 1:14 PM 2/24/2008
Old Feb 24, 2008 | 11:18 AM
zex_cool's Avatar
eCtune sells them for 65.
Old Feb 24, 2008 | 11:33 AM
Default Re: (zex_cool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zex_cool &raquo;</TD></TR><TR><TD CLASS="quote">eCtune sells them for 65. </TD></TR></TABLE>
I read on some RX7 forum that there was a place that sells them online for $22, but I couldn't find the damn link.
Old Feb 24, 2008 | 04:26 PM
zex_cool's Avatar
Default Re: (Boostwerks.com)
22bux ? ****, thats a killer deal.
here is the one from eCtune. its actually 67.50 +s&h;
http://forum.ectune.com/viewtopic.php?t=217
i think you have to be a member to look at it tho.
Old Feb 24, 2008 | 07:17 PM
Default Re: Hondata solenoids (Boostwerks.com)
From a mystery poster's PM:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">STC valves, I've tired them out before since I could order them through work for nothing. Out of 4 valves 2 worked and one experinced a thermal failure, I know it sounds odd but the coil got hot enough to actually melt the wires going into it (turned multi strand wire into solid). Maybe it was just a bad batch but I just thought I'd let you know since you expressed interest in it. I won't post this info on here since all that'll end up happening is I'll get banned from being mean again.....they like you more hahahaha.</TD></TR></TABLE>
Sad the way some forums are run. Anyway, like I posted in the other solenoid thread currently on the top page of the FI forum, solenoid failure can be caused by incorrect cycling frequency aka operator error. However, as I stated SCT are chinese as hell and a one in four failure out of the box isn't promising - you get a better success rate with SSAC T3/T04E failure turbos.
vu337
Dec 30, 2009 01:18 PM
SpoolnG2
Feb 29, 2008 12:17 PM
crxsiperf
May 31, 2006 06:02 PM
Boostage
Dec 15, 2005 12:00 AM
blueturboteg
Nov 24, 2003 06:21 AM
