Does Hondata do boost control like the aEM EMS and uego
Old May 31, 2006 | 08:57 AM
crxsiperf's Avatar
* B A N N E D *
Default Does Hondata do boost control like the aEM EMS and uego
I have an ems but was thinking of switching to the hondata because it looks easier to use . Now i have a perrin boost solenoid that can be controlled by just the aem , can the handata also do that ? And will the hondata except the output wire from my aem uego gauge to read airfuel , i dont have a stock snesor anymore.
Thanks
Old May 31, 2006 | 09:03 AM
turbotime's Avatar
well im not tuner but i dont think hondata can control boost on a solenoid like that, also it cant take wideband input, it only takes the normal o2 voltage
Old May 31, 2006 | 09:24 AM
PrecisionH23a's Avatar
Default Re: Does Hondata do boost control like the aEM EMS and uego (crxsiperf)
K-pro can... but as far as I know the s300 units do not have that option as of yet. I was told by Doug that the boost controller option has not been ruled out yet though and may be available at some point in time.
Old May 31, 2006 | 10:35 AM
ladysman's Avatar
Default Re: Does Hondata do boost control like the aEM EMS and uego (PrecisionH23a)
I think the S300 does. I will check the software when I get home.
Old May 31, 2006 | 10:48 AM
Default Re: Does Hondata do boost control like the aEM EMS and uego (ladysman)
The s300 only has boost cut... unless I have an out of date version of the software.
Old May 31, 2006 | 12:45 PM
Silverbeast's Avatar
You can not control boost like you can with the Kpro, you're right.
But I wouldnt rule it out
Old May 31, 2006 | 05:35 PM
ladysman's Avatar
Default Re: Does Hondata do boost control like the aEM EMS and uego (Silverbeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverbeast &raquo;</TD></TR><TR><TD CLASS="quote">You can not control boost like you can with the Kpro, you're right.
But I wouldnt rule it out </TD></TR></TABLE>
Yep, sorry, I was thinking K-Pro. I knew I saw it somewhere.
Old May 31, 2006 | 05:46 PM
tony1's Avatar
You could make something work with the nitrous functions, but it wouldn't be a PWM control.
Old May 31, 2006 | 06:02 PM
Mase's Avatar
Default Re: Does Hondata do boost control like the aEM EMS and uego (tony1)
a guy in minnesota used the nitrous out put and made his own controller, i havent seen it, but he says it works.
vu337
Dec 30, 2009 01:18 PM
dev203d
Engine Management and Tuning
Nov 12, 2009 06:48 PM
Boostage
Dec 15, 2005 12:00 AM
gstintegra92
Aug 21, 2003 09:20 PM
Acura_I-RS
Mar 3, 2003 11:56 AM
