Hondata ROMeditor....What do you want in the next release?
#26
Re: Hondata ROMeditor....What do you want in the next release? (fastludeh22)
comparable to any other tuning software it is relatively inexpensive. And the romulater just makes it easier to tune, not needed entirely.
#28
Re: Hondata ROMeditor....What do you want in the next release? (philipwight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philipwight »</TD></TR><TR><TD CLASS="quote">comparable to any other tuning software it is relatively inexpensive. And the romulater just makes it easier to tune, not needed entirely.
do you have to use they're burner and romulator? i can get ones around here cheaper then all the ones i see on the net.
#30
Re: Hondata ROMeditor....What do you want in the next release? (b16coupe)
Higher resolution for the tables under boost, IAT correction, and an output for a boost controller. That would pretty much be everything I could ask for. Although the software is already 90% perfect IMO.
#31
Re: Hondata ROMeditor....What do you want in the next release? (PureTeg420)
It would be nice to have control of the engine temp and air temp fuel/timing correction.
#33
Re: Hondata ROMeditor....What do you want in the next release? (hybrid901)
i have the chip burner that they Hondata sells but use a different one because it is much easier to use. But as a dealer i recommend the hondata supported one.
#34
Re: Hondata ROMeditor....What do you want in the next release? (rota92)
I'd like to see different settings for the IACV for the 3 startup stages.
What's the issue with the IAT?
#35
Re: Hondata ROMeditor....What do you want in the next release? (XES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XES »</TD></TR><TR><TD CLASS="quote">You need to be able to save the custom O2 sensor voltage conversion (when setting up a wideband). If you tune many different cars with different widebands using the same laptop you always have to re-enter the values if you switch back to one of the defaults (i.e. FJO, etc.). There could also be more rows to enter AF & voltage values - instead of only 12.
I think this is a good request. Seems like not such a big deal for them to include. There are more WB out now than when I first got my system. So more options for WB tables!!
#36
Re: Hondata ROMeditor....What do you want in the next release? (TitanDarin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TitanDarin »</TD></TR><TR><TD CLASS="quote">It would be nice to have control of the engine temp and air temp fuel/timing correction.</TD></TR></TABLE>
I agree with that suggestion. Anything in the software that is similar to what is seen with the Power FC (in terms of % less fuel per X amount of degrees hotter or cooler).
