Hondata questions......
Old Jun 16, 2003 | 11:49 AM
legendboy's Avatar
Default Hondata questions......
We tuned my roomates car this weekend and I have a couple hondata questions. This was our first hondata/dyno tune and I have to say it was really easy!
First thing, Do honda's idle in open loop??
Second thing, When dyno tuning a honda, should I let the car run for a minuite until the ecu switches from the startup map before making a run? They seem to run really rich for around 30 seconds after you start them up.
We made 194.2hp and 157lb/ft at 8psi running a safe 12:1 in boost and total timing of 22deg under full boost. The power curve looked good and the a/f was bang on.
D16Y8, T3 .42 / .48, hondata 2b, ssq, small spearco type ic, 440 rc's.
This was actually a retune. The map we pulled off the chip was tuned my someone else in town. We pulled it after he melted a piston only to discover that he was running 29 degrees advance under full boost and he was hitting 14.5:1 after the vtec change over. (after half a baseline run)
Modified by legendboy at 2:31 PM 6/16/2003
Old Jun 17, 2003 | 12:31 PM
legendboy's Avatar
Default Re: Hondata questions...... (legendboy)
bump
Old Jun 17, 2003 | 01:33 PM
sparkz's Avatar
yes honda's idle in open loop. ive tuned my idle to about 14.5-14.7 afr in open loop.
Old Jun 17, 2003 | 09:11 PM
legendboy's Avatar
Default Re: Hondata questions...... (sparkz)
thanks for the reply. thats what I figured. any ideas about the start up fuel map?
Old Jun 17, 2003 | 11:20 PM
sparkz's Avatar
startup fuel map? there isnt any map thats specific to start up available on hondata (at least on the version i have) are you talking about cranking fuel adjustment? i left that and throttle tip adjustment as defaults which is the same as injector multiplier. ive also noticed that about within 30 secords after startup, my map area around idle shows up leaner when what i have previously tuned to (14.7) but once i bring the revs up and start driving a bit, it goes back to about 14.7ish
Old Jun 18, 2003 | 12:33 AM
Dee's Avatar
Dee
Make sure the TPS and timing settings are correct.
DBallz
Apr 29, 2004 11:39 AM
durden
Jan 3, 2004 03:10 PM
GOLDBERG
Apr 29, 2003 09:03 AM
kaneda3
Jan 23, 2003 11:31 PM
