hondata question
Old May 12, 2003 | 09:01 PM
CM-R's Avatar
Default hondata question
i have a s200 and i want to change my shift light rpm, but i was wondering if my ecu/s200 has to be connected to my car when i hook it up to my computer? i dont have a laptop to change the setting with...plus i hate that the s200 system cant be changed with the rpm button anymore like my 4b did
Old May 12, 2003 | 09:10 PM
Flamenco-T's Avatar
Default Re: hondata question (CM-R)
you need to get your old map where your current chip is on the ECU, modify the MAP to where you can change the rev limiter, then reburn the chip and plug it back in on the ECU.
how often are you gonna change redline anyway ?
stan
Old May 12, 2003 | 09:45 PM
CM-R's Avatar
Default Re: hondata question (Flamenco-T)
oh im not changing the redline im changing the shift light point...it was easier with the 4b when i can use the button instead...
BUCK_NASTY
Apr 21, 2007 02:39 AM
dfn_doe
Jan 7, 2006 07:40 AM
youngvedder
Jul 27, 2005 11:36 AM
2k1_ITR_0736
Feb 2, 2004 01:16 PM
