Hondata Problems ~rom included~
Old Aug 26, 2003 | 10:35 AM
legendboy's Avatar
Default Hondata Problems ~rom included~
I have been suffering from some weird problems. I have interminently the 3000rpm hesitation problem but with my problem, as soon as it starts it continues to get progressivly worse until the car won't drive at all and then it dies. Then it just goes away. My ecu was sodered by an electrical engineer friend and its perfect. All cables are secure. Again this problem is intermitent.
Second problem is with warm start and operation. It takes at least 10 crank to start the car after its warm. And the car has started to die occationaly at idle after its warm. I've included my tuned rom for anyone to have a look at. (v2.5)
I'm running dsm injectors. LS Integra
My ROM <u>here </u>
Old Aug 26, 2003 | 10:39 AM
legendboy's Avatar
Default Re: Hondata Problems ~rom included~ (legendboy)
Static timing is set to 13 degrees in the rom editor. The low cam map should look like this.
Old Aug 26, 2003 | 10:59 AM
psileepR's Avatar
New User
its your injectors .. for the hot start problem.. i dont know about the part throttle hesitation.
if your car isnt tuned yet ... then take it in...
as for starting the car when its hot/warm ... pump the gas as you are cranking it.
it takes a lil practice but u will get it.
ps i am swapping my dsm's once i have the money.
Old Aug 26, 2003 | 11:15 AM
legendboy's Avatar
Default Re: Hondata Problems ~rom included~ (psileepR)
Car is tuned perfectly to 12:1 a/f. Timing is good, honda "lump" is gone.
I know of quite a few people who run dsm injectors without problems.
Old Aug 26, 2003 | 11:18 AM
ladysman's Avatar
If I get time tonight, I will take a look at it. A datalog would help too if you have one. Really can't tell much with just a rom.
Old Aug 26, 2003 | 11:20 AM
LiLOtaku's Avatar
Is your car an obd2 car?
If it is, your going to have to pull the "evap purge valve" on your car. This is the main cause of bad startup after the car is warm. Hondata recommends to do this with all obd2 cars using obd1 ecu's with hondata.
If your car starts up fine after a cold start, and won't start up to well after a warm start, then that most likely is your problem.
Old Aug 26, 2003 | 11:21 AM
Mr. Softee's Avatar
Default Re: Hondata Problems ~rom included~ (LiLOtaku)
the start prob is definitely the dsms, mine do it too.
Old Aug 26, 2003 | 11:33 AM
LiLOtaku's Avatar
I was taking a look at your rom file and you have some fuel tables that are crossing on your high speed fuel table. It starts at ~5k rpm and stays throughout the whole rpm range afterwards.(2d chart)
As far as I know, fuel tables should not cross, this usually causes hesitation and what not.
Old Aug 26, 2003 | 11:34 AM
legendboy's Avatar
Default Re: Hondata Problems ~rom included~ (94goldjungsr)
Car is OBD1. (94)
My roomate and my friend have the exact same warm start issues. Ones using RC 440's and the other is using RC 550's.
Old Aug 26, 2003 | 11:37 AM
Mr. Softee's Avatar
post a screenshot of hte rom file's fuel table for those of us who dont use hondata
Old Aug 26, 2003 | 11:57 AM
LiLOtaku's Avatar
low fuel
If you need the actual table for the low fuel map, its up top(2nd post). As you can see, he's leaning out quite a bit at around 3k and up(massive dip).
If you feel like messing with your maps a little more with a wideband 02, take this into consideration. Every 10% you increase/decrease fuel on the map is ~1 a/f point on your 02 meter.
"edit for non-vtec"
Modified by LiLOtaku at 2:09 PM 8/26/2003
Modified by LiLOtaku at 2:13 PM 8/26/2003
Old Aug 26, 2003 | 12:05 PM
legendboy's Avatar
Low Fuel
Injector Duty Cycle
Old Aug 26, 2003 | 12:11 PM
legendboy's Avatar
For anybody looking at my maps, you only use the low fuel and spark maps for non vtec.
Old Aug 26, 2003 | 12:15 PM
LiLOtaku's Avatar
You could always try adding a little more fuel to where that large dip is and then interpolate it a bit to see if that helps a bit.
Thats a pretty large lean dip.
Old Aug 26, 2003 | 12:26 PM
legendboy's Avatar
Car is tuned perfectly to 12:1 a/f at wot, these weird hesitation problems are in closed loop
Old Aug 26, 2003 | 07:05 PM
Hondata's Avatar
Some DSM injectors cause problems with starting and idling. When this happens replacing them with RC 440 injectors fixes these problems. Do this first.
As for your fuel maps, all the lines should be parallel and evenly spaced (like the bottom 10 lines) - not as you have displayed.
Modified by Hondata at 8:23 PM 8/26/2003
Old Aug 27, 2003 | 06:53 AM
legendboy's Avatar
Default Re: Hondata Problems ~rom included~ (Hondata)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondata &raquo;</TD></TR><TR><TD CLASS="quote">As for your fuel maps, all the lines should be parallel and evenly spaced (like the bottom 10 lines) - not as you have displayed.
Sorry, I dont understand your logic behind that statement. We tuned the car on a mustang dyno to 12.5:1 at wot before boost. The lines are where they need to be in order to have that a/f ratio. Much apreciated if you could elaborate a bit for me. Thanks.
Old Aug 27, 2003 | 06:55 AM
legendboy's Avatar
oops, double post
Old Aug 27, 2003 | 07:05 AM
ekb18c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiLOtaku &raquo;</TD></TR><TR><TD CLASS="quote">low fuel
If I were you, I would go back and tune again.
Old Aug 27, 2003 | 07:33 AM
legendboy's Avatar
Default Re: Hondata Problems ~rom included~ (ekb18c)
could somebody please explain
Old Aug 27, 2003 | 07:46 AM
rage2's Avatar
Alright, let me try to help out with the details of the fuel map here. I helped legendboy tune his car on the dyno.
First off, ignore all the boost plots below ~2800rpm. The car has a big turbo, and doesn't start to build boost until the 3000rpm mark, even in high gears. So those plots are irrelevant.
The "dip" in the fuel curve you see at ~3500rpm to ~4300rpm is there because the turbo is (I'm guessing) out of it's efficiency range, therefore the air is not as dense as the boost level suggests. If we "flatten" it out by richening it, we'll get a nice rich spot in that rpm range, and get a nice dip in power. The car is tuned to 12:1 A/F ratio that's as flat as utah. A/F goes from 13:1 off boost, to 12:1 at around 4psi, and maintains 12:1 at all boost levels. Remember, this is a fuel curve, under boost, it's NOT a direct relationship with the A/F ratio, because of compressor efficiency differences at different compressor speeds (unlike a NA curve, the bottom 10, which are linear because VE doesn't change much over a large rpm range).
So, the question is, is there any settings we can use to "trick" hondata into changing the warm up fuel curve?
Old Aug 27, 2003 | 03:48 PM
legendboy's Avatar
ttt
Old Aug 28, 2003 | 11:02 AM
Mr. Softee's Avatar
Default Re: (legendboy)
that is a ton of fuel. what injectors do you have?
also are you having hesitation problems at partial throttle? if so there is a 3 or 4 page thread on that.
sam
Old Sep 2, 2003 | 10:07 PM
Buster T's Avatar
Hondata,
Hi, I bought a car with a PR3 and a Hondata Stage 2B, t3/t4 turbo on a B18c1 using RC 440 cc injectors.
I am having some problems with hot start-up and with idling once the car is warm. The car dies at stoplights and is very hard to restart sometimes.
I have not changed the set-up of the car, except for taking care of some exhaust leaks. I also had an igniter go bad in my distributer, which I replaced with a factory new GS-R igniter.
My question is: Could the injectors be out of spec? Like sticking at idle and letting too much fuel drip in and flood the motor, causing the car to die?
I am asking because the car did not used to do this. The nearest Hondata tuner is 550 miles away.
I would appreciate any help or suggestions. The car runs flawlessly at partial and wide open throttle.
Thank you.
PR8urVtec
Engine Management and Tuning
Oct 1, 2014 01:54 AM
FinallyBoosted
Apr 27, 2007 04:52 PM
TEG777
Sep 22, 2005 04:47 AM
95 integra
Jun 14, 2004 06:08 PM
ActiveAero
Jan 1, 2004 01:54 PM
