Hondata problem?
Old May 11, 2003 | 11:07 AM
blue99turbo's Avatar
Default Hondata problem?
I just got my s-200b working with a base map from Hondata. Car ran fine idled perfect for 2 days. Now today after 2 hrs. of normal driving around the car died at a light. I got it started and made it home but it died when I pulled into driveway and now if I can get it to start even when holding gas down the rpms will jump a little than it will die again. Any idea whats wrong now?
Old May 11, 2003 | 11:08 AM
Sonny's Avatar
Default Re: Hondata problem? (blue99turbo)
Sounds like you have a loose connection somewhere.
Sonny
Old May 11, 2003 | 11:59 AM
psi420's Avatar
Yah, check your OBD conversion harness.
Old May 11, 2003 | 06:07 PM
Default Re: (psi420)
I checked and all my connections are good. I let the car sit for about 2hrs and it started right up. I can tell its dumping to much fuel now thats why it wouldn't crank but how could it have changed? When I start it now it spudders when I press the gas from to much fuel.
Old May 11, 2003 | 06:11 PM
Spunkster's Avatar
Default Re: (blue99turbo)
Are you sure you have a base map? They are not shipped from Hondata with basemaps.
playahwitgame
Jul 7, 2006 10:38 PM
civel
Mar 16, 2006 03:20 PM
Kwuaymaikrup
Oct 5, 2005 02:40 AM
Smashback
Mar 8, 2003 05:19 AM
MRSI00
Jan 20, 2003 11:35 PM
