Hondata Pocket programer power transistor.
Old Jun 30, 2002 | 03:35 PM
falcongsr's Avatar
What is this crap?
Default Hondata Pocket programer power transistor.
Does anyone know the power transistor's part # that usually fries on the board? I need the part # to replace it.
Old Jun 30, 2002 | 03:49 PM
CovertFI's Avatar
Default Re: Hondata Pocket programer power transistor. (falconGSR)
there are no markings on it?
Old Jun 30, 2002 | 04:02 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Hondata Pocket programer power transistor. (CovertFI)
Its burnt you cant read it. I saw it..
art
Old Jun 30, 2002 | 05:22 PM
CovertFI's Avatar
Default Re: Hondata Pocket programer power transistor. (Arturbo)
i have never burnt one that bad. damn
Old Jun 30, 2002 | 05:42 PM
falcongsr's Avatar
What is this crap?
u can see its got a silver face. there is not a part number on it though, just some wierd company name i think.
the other 'power transistors' were 2N4491. Maybe that's what this one is. I can't afford to guess though, its not my unit.
Old Jun 30, 2002 | 09:10 PM
Stock@$$GSR's Avatar
What causes that transistor to fry?
Old Jun 30, 2002 | 10:10 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Hondata Pocket programer power transistor. (Stock@$$GSR)
When you power up the programer it is defalted to 25V, when you only need 5V. So what happend was that the emulator was left in the programer when we powered it up and it fried the power transistor. What needs to be done is leave the emulator out, power it up, and download map. When you download the map, it will drop the voltage from 25v down to 5v where you need to be.
art
Old Jun 30, 2002 | 11:47 PM
TurboCivicSi's Avatar
Art.. Cal HonData, they will send you out a new programmer.. Doug informed me that they are aware of the problem, and have ordered a bunch of them...
My Programmer burned while I was actually running the car on my Emulator..
Doug told me that if you use them for more than ten minutes at a time, they can get hot and overheat, also causing this failure..
I am suppossed to get mine Tomorow morning..
-Jason
Old Jul 1, 2002 | 08:48 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Hondata Pocket programer power transistor. (TurboCivicSi)
Well this was my new programer and I was dumb enough to leave the emulater in there and it burned. I was totally my fault and I dont want to send this back because of that. I would rather just change the part since we have infinate transistors from Falcongsr. I cant belive I did that twice!!
So, does anyone have the part #?
art
Old Jul 1, 2002 | 02:38 PM
DIRep972's Avatar
Smarter than you
Up...
Old Jul 1, 2002 | 04:02 PM
sgT's Avatar
sgT
art
Im surprised mine is still good, since i do that all the time.
of course now that i've said this it will go the next time i try to use it.
Old Jul 1, 2002 | 04:47 PM
falcongsr's Avatar
What is this crap?
Default Re: Hondata Pocket programer power transistor. (sgT)
so could you take yours apart and tell me what that transistor says on it? the one in the pic is pretty fried.
Old Jul 1, 2002 | 07:06 PM
Arturbo's Avatar
Better than steak
25 Year Member
Please sgt, I need to burn a chip. I miss my car.
Also, Ive seen these transistors on the other side of the board.
art
Old Jul 1, 2002 | 08:21 PM
SlowTeg's Avatar
Alright, I'll give it a shot.. I'm not very familiar w/ electronics but I'll read what I can off of the resistor..
- 2n
44U1
M7??
That's how it looks in each row. The last row has some strange symbols, so I used ? marks.. On another note.. This pocket programmer I have for some reason seems to have stopped working. Is there anything else that could cause it to stop working properly? Nothing looks burnt on the board, and it simply just stopped working on day...?
-Mike
Old Jul 1, 2002 | 08:24 PM
falcongsr's Avatar
What is this crap?
Default Re: Hondata Pocket programer power transistor. (SlowTeg)
- 2n
44U1
M7??
ok so you're telling me the resistor on the side with almost no other components says
2N
44?1 ...and the other similar looking components on the other side have the same markings on them? if you could please verify that for me i would appreciate it. It makes sense, i just need confirmation.
Joe
Old Jul 1, 2002 | 08:31 PM
SlowTeg's Avatar
Yup, they're all the same.
-Mike
Old Jul 1, 2002 | 08:45 PM
falcongsr's Avatar
What is this crap?
thanks!
now i need to find a crossreference part number for that. cant find any 44U1...
Old Jul 1, 2002 | 08:51 PM
SlowTeg's Avatar
No problem man.. I don't actually think it's a U... it's probably some other damn symbol that looks alot like it.. Although I could be wrong...
-Mike
Old Jul 1, 2002 | 09:00 PM
falcongsr's Avatar
What is this crap?
thanks for the help, i should be able to have someone identify it at work.
or maybe Doug @hondata will post about it
Old Jul 2, 2002 | 08:54 AM
falcongsr's Avatar
What is this crap?
i found it! its a 2n4401. i'll try to get a replacement.
Old Jul 2, 2002 | 09:09 AM
sgT's Avatar
sgT
Hope you guys get it fixed.
Mike: maybe i should take a look at your programmer.
Old Jul 2, 2002 | 10:11 AM
falcongsr's Avatar
What is this crap?
radio shack had it in stock! Cat No 276-2058... 69 cents.
avex
Jun 24, 2003 05:44 AM
Asahi
Jan 30, 2003 06:13 PM
tygsr
Jul 4, 2002 06:42 PM
