hondata map sensor on stock setup
Old Sep 2, 2009 | 02:11 PM
jetspeedz's Avatar
Default hondata map sensor on stock setup
Guys ill be getting a hondata 4 bar map sensor. I just had a questions but i think i already know the answer to this. I can't run a hondata map sensor on the stock ECU correct b/c the values 0-5v will be different between this sensor and the oem map sensor correct?
Ill have to test the sensor manually when it arrives just to test it till the kit goes on and its boosting i assume.
Old Sep 2, 2009 | 04:32 PM
jsbayer's Avatar
Default Re: hondata map sensor on stock setup
Correct, you will need hondata or some other ems system.
Old Sep 2, 2009 | 05:16 PM
jetspeedz's Avatar
Thanks for the confirmation. Ill have to test it manually before putting it on
Todallybuilt
Engine Management and Tuning
Oct 29, 2017 06:05 AM
Todallybuilt
Oct 15, 2017 06:18 AM
Dave_yd
Mar 24, 2008 12:57 PM
