hondata dataloging question...already searched
when i get hondata im going to get the datalog option. my quesition is how does it log air/fuel, or can it? i have no problem buying a wideband like you do with aem, but they dont list anything on their website that i found. any info would be appreciated.
Landon
Landon
Re: hondata dataloging question...already searched (boosted_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 »</TD></TR><TR><TD CLASS="quote">when i get hondata im going to get the datalog option. my quesition is how does it log air/fuel, or can it? i have no problem buying a wideband like you do with aem, but they dont list anything on their website that i found. any info would be appreciated.
Landon</TD></TR></TABLE>
If you buy a wideband kit it comes with a display that shows your AF ratio
New User
log onto hondats website and go to the tech section. it has a write up of how to wire int he wideband to your stock harness so you can datalog. the display is only really beneficial for setting up the unit with the laptop. but the wiring is easy. check it out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 »</TD></TR><TR><TD CLASS="quote">yea but i want to plot it with RPM's so i can do minor tunes. </TD></TR></TABLE>
And that is exactly what it does in Rom Editor when you datalog. It tells you on each square of the plot what the percent difference is (From what you set it at), the actual A/F. Here is a screen shot of the percent difference.
HTH
HTH
columns are the different load points, rows are rpms. its basically telling you that in that particular cell in the fuel map you are that percentage off.
Re: hondata dataloging question...already searched (racerxadam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerxadam »</TD></TR><TR><TD CLASS="quote">columns are the different load points, rows are rpms. its basically telling you that in that particular cell in the fuel map you are that percentage off.</TD></TR></TABLE>
Bingo.
Sorry, I never got that anyone responded to my post otherwise I woudl have.
Bingo.
Re: hondata dataloging question...already searched (ladysman)
not to be an idiot but what are load points??? im used to seein a plot with rpm's, air fuel, and hp. then you go to the setting and just adjust where you need to trim or add fuel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 »</TD></TR><TR><TD CLASS="quote">not to be an idiot but what are load points??? im used to seein a plot with rpm's, air fuel, and hp. then you go to the setting and just adjust where you need to trim or add fuel.</TD></TR></TABLE>
nah you got it wrong...
Its RPM vs Load Point (ie. 1 psi, 8 psi, -4 psi vac) vs. Fuel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 »</TD></TR><TR><TD CLASS="quote">oh is that what the mbar an psi rows are????</TD></TR></TABLE>
pressures is what i ment to ask
projectef
12-16-2006 04:56 PM
