Hondata & CPR injectors prob.
Old Apr 19, 2003 | 10:31 AM
g2turbo's Avatar
Default Hondata & CPR injectors prob.
Well just having a few small problems still getting the injectors to not leak. My instructions say to use a factory honda oring at the top where the injector slides into the rail. Do you guys use vaseline or something similar to let the oring slide easier cause i think im ripping the orings when i put them in the rail.
Before i noticed the injector was leaking the car was running fine at idle but when i went to give any throttle it would fall on its face. At that time only 1 of the injectors was leaking. WOuld this be causing it to not run right
by the way its a hondata s200b with 550cc saturated cpr injectors.
Old May 7, 2003 | 11:01 PM
redline201's Avatar
Default Re: Hondata & CPR injectors prob. (g2turbo)
ttt
Old May 7, 2003 | 11:04 PM
BrokenVtec's Avatar
Default Re: Hondata & CPR injectors prob. (redline201)
get new o-rings and use some sort of engine lubricant to get them in easier....
the leak would make your car run that way.....good luck
Old May 8, 2003 | 12:29 AM
GOLDBERG's Avatar
Default Re: Hondata & CPR injectors prob. (BrokenVtec)
yeahu needa lube that baby up
Old May 8, 2003 | 07:10 AM
b18bturbo's Avatar
Default Re: Hondata & CPR injectors prob. (GOLDBERG)
definitely need to lube it up throughly and it slides right in... just put some vasoline which works wonders
Old May 8, 2003 | 07:12 AM
g2turbo's Avatar
Default Re: Hondata & CPR injectors prob. (b18bturbo)
hey guys i got the problem taken care of a few weeks ago this is an old post. thanks to viren for the injectors they work well!
Old May 8, 2003 | 07:13 AM
b18bturbo's Avatar
awesome..
Old May 10, 2003 | 11:19 AM
krazy's Avatar
glad i saw this post. can i use fresh oil as well. im afraid vaseline may detoriorate the rubber somehow. this is the stock fuel rail right? thanks guys
krazy
Old May 10, 2003 | 01:16 PM
eg6turbo's Avatar
Default Re: Hondata & CPR injectors prob. (krazy)
yeah, viren sells the cpr injectors that are already machined to fit honda rails...well rubber and vasiline might not mix to well cause its petroleum based...K-Y jelly will work water based but not oo sure...just dont put alot of whatever u use....its saturday now and i hope my 440cc from viren gets here on monday....
Old May 10, 2003 | 01:36 PM
Spunkster's Avatar
What on earth does leaking injectors have to do with Hondata?
070-racing
Feb 2, 2017 01:21 AM
TokuiAutowerks
Jun 19, 2008 06:02 PM
integracivic94
Dec 30, 2003 06:49 AM
SpeedMonkeyRacing
Sep 7, 2002 08:13 AM
Brian_92GSR
Nov 18, 2001 09:04 AM
