Hondata,Aem,SDS,Uberdata,ext.
Old Feb 10, 2006 | 11:20 PM
JLHDOHC's Avatar
Default Hondata,Aem,SDS,Uberdata,ext.
I just got my all the parts to put my new build together 84.5 Darton sleeved boosted Gsr block with wiseco 8:8:1 compression pistons and eagle rods arp rod bolts,main studs,Gsr crank and the whole thing has been balanced and gone through very well the head is the original gsr head with the works..I really wanna push the motor its going to be ran a lot on the strip..What would you suggest for a Fuel management system!!! just got my taxes and I dont wanna melt a piston again so whats good....
Old Feb 10, 2006 | 11:48 PM
mtber's Avatar
Default Re: Hondata,Aem,SDS,Uberdata,ext. (JLHDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JLHDOHC &raquo;</TD></TR><TR><TD CLASS="quote">I just got my all the parts to put my new build together 84.5 Darton sleeved boosted Gsr block with wiseco 8:8:1 compression pistons and eagle rods arp rod bolts,main studs,Gsr crank and the whole thing has been balanced and gone through very well the head is the original gsr head with the works..I really wanna push the motor its going to be ran a lot on the strip..What would you suggest for a Fuel management system!!! just got my taxes and I dont wanna melt a piston again so whats good.... </TD></TR></TABLE>
All of these systems get the job done. What you need to look at is the features of each system & which system you can get tuned by a reputable tuner in your area.
Old Feb 10, 2006 | 11:50 PM
Dunc's Avatar
BCICAN
Default Re: Hondata,Aem,SDS,Uberdata,ext. (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">
there is no "BEST" engine management out there.
depends on different opinions options and needs.
^^^^Personally I like this quote. This was just discussed in this thread: https://honda-tech.com/zerothread?id=1519171
Old Feb 11, 2006 | 12:10 AM
Adriano's Avatar
Default Re: Hondata,Aem,SDS,Uberdata,ext. (Dunc)
Talk to whoever is gonna tune the car and ask that person what EMS to get. If you are gonna tune it yourself, I would get the AEm since all it needs is a laptop to tune with it.
Adriano
EnzoSpeed's Avatar
Well I can tell you right off the bat that Uberdata isn't the best, or the easiest to work with, or the easiest to find a tuner for. The only real benefit is that it's the cheapest.
Old Feb 11, 2006 | 08:15 AM
JLHDOHC's Avatar
Default Re: Hondata,Aem,SDS,Uberdata,ext. (EnzoSpeed)
No doubt about that is there!!!
Old Feb 11, 2006 | 01:48 PM
JLHDOHC's Avatar
How is the SDS program and setup on a Honda
as to Hondata..........
Old Feb 11, 2006 | 05:22 PM
JLHDOHC's Avatar
bump!!!!(someone)
Trojan Man
Nov 9, 2012 07:50 PM
Superqwak
May 24, 2011 06:28 AM
little2fast4u
21
Aug 28, 2008 03:06 PM
wreckedmyteg
Jan 13, 2005 08:05 PM
90da6
Dec 3, 2004 11:37 PM
