Hondata with 2 boost settings
Old Dec 21, 2003 | 12:08 AM
BlackThorN's Avatar
Default Hondata with 2 boost settings
ok, I'd like to have 2 different boost settings and I was planning on running hondata, i'd like to run .5bar daily and have the ability to run 1 bar if I want too without getting it totally retuned at a shop (like at the track ect)
is this possible, to have 2 different programs made for my car, would I need a seperate boost controller?
or would I just have to replace the spring in the wastegate and let the hondata cut the fuel on the high end
I just don't understand how this works, if there's a place I can read up on it I"d appreciate it
thanks in advance
Old Dec 21, 2003 | 12:14 AM
PrecisionH23a's Avatar
Default Re: Hondata with 2 boost settings (BlackThorN)
With hondata you tune for the maximum desired boost. You can then change your boost settings via boost controller/wastegate from X pounds to the desired max boost the motor has been tuned to without needing separate maps.
Old Dec 21, 2003 | 12:18 AM
BlackThorN's Avatar
WOAH, super fast response
thank you so much for responding
will the car run as well at the lower boost setting if tuned for higher boost?
Nick
Old Dec 21, 2003 | 12:40 AM
Default Re: (BlackThorN)
yes it will. If i wasn't half asleep right now I would go into detail and explain how exactly hondata does this.
Old Dec 21, 2003 | 12:51 AM
BlackThorN's Avatar
Default Re: (GudeH23a)
well I look foreward to more info
thanks again this helped my project so much
HondAcura
Northeast (Sales)
Jul 14, 2006 03:37 AM
BLWNB16A@11psi
Jun 22, 2005 08:27 PM
btrim23
Feb 26, 2005 02:32 PM
JusT a Cx
Feb 24, 2004 05:58 PM
5thgencivic
Sep 17, 2003 06:41 PM
