Hondalogger question
Old Jul 16, 2002 | 11:17 PM
sparkz's Avatar
Default Hondalogger question
Scenario: Hondata stage 2b w/datalogging
If I hookup a wideband o2 (diy-wb) in place of old o2, can I log the values in hondalogger after changing the lambda values to match with the diy-wb? What effect does this have with open loop since hte voltage values are different between diy-wb and factory o2? Will the ECU go crazy in open loop?
I was thinking just make WOT runs and only log that portion?
Old Jul 17, 2002 | 01:21 AM
VaporTrail's Avatar
New User
Default Re: Hondalogger question (sparkz)
http://www.hondata.com/motecplm.html
Old Jul 17, 2002 | 12:09 PM
sparkz's Avatar
Default Re: Hondalogger question (VaporTrail)
Hooking upt he wideband is understood but I guess my real question is will it run fine it closed loop mode when the ecu expects a range of 0-1 v?
Old Jul 17, 2002 | 12:25 PM
dustin's Avatar
You cannot do closed loop w/ the wideband on Hondata. You'll have to turn off closed loop to drive with it.
Old Jul 17, 2002 | 12:34 PM
sparkz's Avatar
Default Re: Hondalogger question (dustin)
Ahh, thanks for the answer. This is a stage 2bd so theres no way to set it open loop unless I have a stage 4 system right? bummer
Old Jul 17, 2002 | 12:36 PM
dustin's Avatar
yeah you'd have to find a friend with 4b.
jbbauer7
Nov 2, 2011 02:47 PM
DaiJekBok
May 24, 2007 08:51 PM
na200whp
Mar 3, 2004 11:19 PM
crx1856
May 29, 2003 01:03 PM
crx1856
May 28, 2003 04:25 AM
