Is it possible to use gsr turbo kit on a LS?
Old 07-16-2002, 09:48 PM
digitalhav0c's Avatar
Default Is it possible to use gsr turbo kit on a LS?
I have access to a gsr turbo kit for very cheap and i was wondering would it be possible to use it on my ls with no complication's ? if i leave the boost 6 - 7 psi?
Old 07-16-2002, 10:18 PM
ceemarun's Avatar
Default Re: Is it possible to use gsr turbo kit on a LS? (digitalhav0c)
its not gonna work w/ the blue box if you plan on using that. other than that, the piping might be a little off.
Old 07-16-2002, 11:26 PM
TheIntegraGuy's Avatar
Default Re: Is it possible to use gsr turbo kit on a LS? (ceemarun)
itll work...not too sure the DP will match perfectly....but everything will work..Just gotta modify the DP and the pipe going to the intake mannifold...I believe they're slightly different..other than that, ditch the blue box...and just use a Vortech FMU or some other type of Fuel Managment...maybe invest in a standalone..
Old 07-16-2002, 11:52 PM
TenaciousC's Avatar
Default Re: Is it possible to use gsr turbo kit on a LS? (J-MiGiRL702)
the charge pipe is different
Old 07-17-2002, 12:16 AM
Mr. Softee's Avatar
Default Re: Is it possible to use gsr turbo kit on a LS? (TenaciousC)
i put a drag kit from a gsr on my ls with no modifications.
Old 07-17-2002, 03:44 AM
Civicdrgrcr's Avatar
Location: WTF DC Racer No Way Turbo Washington., DC, USA
Default Re: Is it possible to use gsr turbo kit on a LS? (94goldjungsr)
I have a intercooler/turbo manifold/for a LS setup.
Intercooler $650 shipped with piping.
Turbo Manifold$600shipped <-- T4 manifold
Turbos 650-750
All parts brand new minus intercooler.
Old 07-17-2002, 05:22 AM
X2BOARD's Avatar
Default Re: Is it possible to use gsr turbo kit on a LS? (Civicdrgrcr)
The kit will fit, but the charge pipe that terminates at the throttle body will not line up properly (or at all) and you will either need to have that one pipe cut and re-welded at an angle, or get a custom charge pipe. Your other options would include bending a new pipe from the I/C to the charge pipe or a hacksaw and extensive use of silicone couplings ($$). But if you are getting a good deal on the GSR kit, go for it, a new or custom charge pipe is easy to get.
X2
Old 07-17-2002, 05:26 AM
cornbread's Avatar
Default Re: Is it possible to use gsr turbo kit on a LS? (X2BOARD)
it looks as if he has a 90 LS will the GSR kit from a 3g fit a 2G ls?
Old 07-17-2002, 01:28 PM
Etylorcen's Avatar
Default Re: Is it possible to use gsr turbo kit on a LS? (smokeeeLSR)
Oh now you're talking about jumping generations...im pretty sure you'll have to rework most of the piping.
jdmxxdc2
04-12-2005 04:49 AM
BoOstInHaRd
01-16-2005 12:41 PM
Accurate GS-R
07-23-2004 06:14 PM
E-spec Tuner
09-16-2003 08:30 PM
LsBoy
03-18-2003 02:10 PM
Quick Reply: Is it possible to use gsr turbo kit on a LS?
