Honda K24/20 Newbie has questions
Old 05-04-2013, 12:38 AM
AE85's Avatar
Default Honda K24/20 Newbie has questions
Hi guys,
I have a Toyota AE85 track car, and are looking to do a K24/K20 turbo conversion in it. So... I see a few people doing this conversion (in RWD), and this isnt my first rodeo with conversions, but I am keen to know which platform K24 and which K20 is the version to go for when considering forced induction. There seems to be 5-6 different K24's to start with, so keen to get some guidance from those that have been there done that. Ill be doing a built motor.
Andrew
Old 05-04-2013, 04:20 AM
TeranceFL's Avatar
Default Re: Honda K24/20 Newbie has questions
k24a2 or a1 block and k20a or a2 head and than try getting yourself a 5spd tranny out of a k20a3 for stronger and longer gears
Old 05-04-2013, 05:58 AM
Moderator
TheShodan's Avatar
The "longer gearing" myth still perpetuates here. A stock 6 speed will be just fine for turbocharging and will keep your acceleration rate throughout the entire powerband. "Spooling longer" does no good if there is no acceleration.
The underlying question is whether or not you plan to build the engine for this particular project to withstand higher cylinder pressures, or if this is to remain stock.
Old 05-04-2013, 09:56 AM
ryguy2588's Avatar
I'm using a K24A1 block because you want to use the K20A2 or S2000 oil pump, and you won't have to shave the oil pump. It just bolts right on. Use a K20A2/K20Z1/K20Z3 head. The K24A2 heads don't flow as much as the K20's do. You can use a K24A1 head and do a VTEC Killer setup too. Those heads are great to port, and they flow great when you are running nitrous, boost, or high compression. I always end up selling my spare K24A1 heads to the guys at Prayoonto. You can make a lot of power on stock sleeves of a K, but you can always sleeve them too.
I like the 5 speed tranny because the 6 speed is soooo short, and I'm lazy lol.
Old 05-04-2013, 09:58 AM
ryguy2588's Avatar
I learned everything I need from K20A.org. There aren't too many people on here doing K stuff, NA or boosted. There are a lot of people on there that are eager to help as long as you read the FAQ in the forced induction forum.
Old 05-04-2013, 11:38 AM
SovXietday's Avatar
6speeds also break a lot, the 5s seem to last longer. I also wouldn't call it "longer" gearing, the 6 speed just has a wider range of gear ratios and better pickup rates.
Old 05-04-2013, 12:25 PM
Moderator
TheShodan's Avatar
Which to me, depending upon the use of the car is well worth keeping. I've found that many people that "break" the 6 speeds tend not to know what they're doing when driving. those that road race and other forms of endurance racing, seem to have less of an issue with the 6 speeds.
As for K20A.org giving correct information.. Well. I'll just leave a big "?" on that one. Most of the real turbo and NA guys for the K-series that are serious, really don't use that forum as a reference for their particular uses. Other than the "look at my build" portions of the turbo guys, you don't really see much. So your references may be a bit limited in scope.
Old 05-04-2013, 03:46 PM
AE85's Avatar
Im running it in an AE85, so Im guessing a FWD gearbox wont help me
What cars is a K24A1/2 block in? Same with the K20A or K20A2 head?
Old 05-04-2013, 03:48 PM
AE85's Avatar
Ok thanks for the tip.
Old 05-04-2013, 04:49 PM
DirtyDA9's Avatar
Notice that he wants it to be rwd, it will not be mounted transversely.
Old 05-04-2013, 09:11 PM
TeranceFL's Avatar
True didnt really think much about that just didnt want to leave anything out lol
Old 05-04-2013, 10:26 PM
ryguy2588's Avatar
But all of the turbo and NA K guys that are serious are on that forum is what I meant. I learned a ton by just messaging and calling the guys at K-Tuned, Hybrid, Prayoonto, Karcepts when I had questions, and I found it easier just going to a site that specifically used K motors and really nothing else.
The information on there is probably just as good of information on here, but when searching for the specific questions that I needed to figure out when I built my K, almost none of the info came off of Honda-Tech.
Here's a good start:
http://www.k20a.org/forum/showthread.php?t=23830
CRXGUY79
12-05-2018 11:56 AM
dem0nk1d
Engine Management and Tuning
11-07-2008 02:10 PM
rdssk8rcs1
08-16-2007 08:03 PM
Quick Reply: Honda K24/20 Newbie has questions
