Honda civic 300hp turbo build what do I need??
Hey guys been looking into install a turbo on my 1992 civic si with a d16z6. I recently bought a used Garret t3 .48/.60ar turbo. Is this turbo big enough to supply 300hp? Is so what kind of wastegate psi should I run? maybe 12psi?
Now I know that the stock engine will not handle 300hp, and I am prepared to mildly build my engine. I could just use a little advice as to what parts in the block that i need to upgrade. Also If i need to do any head work.
Here is what I know I will need
-Bigger fuel pump
-Bigger injectors
-Dishes forged pistons
-forged rods
-Upgrades pistons seals??
-Headstuds
-maybe upgrades driveshaft?
-Upgraded clutch (Do I need a new flywheel or any other transmission work?)
-Upgraded map sensor (what else would i need for the tune side of things?)
-Along the with all the turbo stuff to supply 300hp. Turbo, wastegate downpipe, charge piping, intercooler, blow of valve etc....
If you guys could help me out in this I would really appreciate it.
This is my first time building or turboing an engine and I'm trying to do it properly and slowly.
-Bigger fuel pump
-Bigger injectors
-forged rods
-Headstuds
Man U FTW
Re: Honda civic 300hp turbo build what do I need??
Before you get ahead of yourself, read the FAQ https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
The questions you're asking could easily be answered through a little research.
A stock D series will make 220-240whp in stock form...more than that requires building it (rods are the weakpoint).
The turbo you have will not make 300whp but is a good turbo for a stock block D.
Eagle rods with ARP fasteners
Cp or vitara pistons (9:1 ratio should work)
Stock head gasket with arp headstuds
Acl race bearing set
Upgraded clutch
450cc injectors
15psi+ on your turbo guesstimate. A bit bigger turbo would be easier especially with the reduction in heat it would yield.
Upgraded clutch
450cc injectors
Aside from what has been mentioned, there is a SOHC thread around here where lots of people post their set ups. Find someone pushing similar power for an idea.
https://honda-tech.com/forums/showth...highlight=SOHC
Specs:
d16y7 Block
Stock sleeves bored to 75.5
Golden Eagle Block guard
CP Pistons 9.0:1
Eagle rods
ACL race bearings
ARP headstuds
OEM Headgasket
Stock d16y8 Head
Transmission:
ACT Extreme pressure plate
Street disc
Lightened Stock Flywheel
Fuel System:
Walbro 255hp fuel pump
AEM fuel rail
Aeromotive FPR
Deatsch Werks 800cc saturated injectors
Exhaust:
GReddy Evo 2
Quicktime Performance 3" cutout
Turbo stuff:
Precision SC61S .63 a/r
Ramhorn mani
3" downpipe (DEI wrapped)
Tial 38mm wasetgate
Turbo elements Back door intercooler (24x8x3.5" core) Anodized black
2.5" intercooler piping
Tial 50mm BOV
Electronics:
P28 ecu (OBD1)
Hondata S300
Hondata Boost Solenoid
Hondata 4 Bar MAP sensor
Apex'I turbo timer
Autometer Boost (30psi), water temp, A/F, and oil pressure gauges
Other:
Energy Suspension motor mount inserts
Fluidyne Radiator
Moroso Catch Can
Hondata Intake Manifold Gasket
Suspension/Wheels/Brakes:
Full-Race Traction bars
Omni Power Drag Coilovers Front and Back
15" Rota Slips w/ Falken Zeix's
Black protective coated OEM calipers
Stoptech Powerslot Rotors
Hawk HPS Pads
Stainless braided brake lines
Interior/Exterior
Type R style civic front lip
Type R Shift Boot
Type R Brake Boot
Mugen Racing II Steering wheel
NRG hub with quick release
Security
Yes.
320.74whp and 253.80ftlbs @ 15psi @ 7.5k (Cut out closed/Full Exhaust)
Coming in the next month:
Fully built head - Bisi 3.6 Cam, Valvetrain, PnP, GE manifold, etc. etc.
Tranny build - Spec mini twin clutch, MFactory LSD, stonger axels.
New tune. Going for 5-600whp.
Specs:
d16y7 Block
CP Pistons 9.0:1
Eagle rods
ACL race bearings
ARP headstuds
OEM Headgasket
Stock d16y8 Head
Transmission:
Street disc
Fuel System:
AEM fuel rail
Aeromotive FPR
Exhaust:
GReddy Evo 2
Turbo stuff:
Ramhorn mani
Tial 38mm wasetgate
Tial 50mm BOV
Electronics:
P28 ecu (OBD1)
Hondata S300
Apex'I turbo timer
Other:
Fluidyne Radiator
Moroso Catch Can
Hawk HPS Pads
Interior/Exterior
Type R Shift Boot
Type R Brake Boot
Security
Yes.
