holset hx35 users i have a question
Old Aug 20, 2009 | 10:41 PM
ITR.#1446's Avatar
Default holset hx35 users i have a question
I just upgraded my turbo on my 05 cummins and have my stock hx35 sitting, i wanna use it on my turbo motor i just built but was wondering what i should do about the exhaust housing. It is electronically waste gated and internal. Can i purchase a new housing with out the wastegate? If so can some one point me in the direction to purchase a housing? thanks
Old Aug 20, 2009 | 10:48 PM
ITR.#1446's Avatar
Default Re: holset hx35 users i have a question
here is what it looks like
Old Aug 21, 2009 | 03:29 AM
AJxr's Avatar
i think thats an he351 or an hy35.
either way very close to an hx35.
what you want to do is take off the solenoid on the compressor side and plug it, or you can just unhook the wastegate actuator from it and leave the solenoid there if you dont mind having extra junk laying around in your engine bay.
next you can keep that housing, just make a bracket to hold the flapper shut or you can be like me and weld the flapper shut.
good luck and thats a great turbo.
Old Aug 25, 2009 | 09:17 PM
ITR.#1446's Avatar
thanks for the info :thumbsup:
Old Aug 26, 2009 | 09:21 AM
spoolin turbo s's Avatar
im pretty sure its an he 351 and its a great performing turbo depending on what engine your talking about putting it on.........you need to pull the electronics, take the turbo apart and make sure the wheels are fixed for top end and not fast spool (im not sure which way these go to do this but i think this turbo will do it itself), but it needs to be done if it doesn't do it its self. weld the wastegate flapper shut
im pretty sure that turbo is good to about 400-475 whp MAXED out
hope that helped
Old Aug 26, 2009 | 01:49 PM
fmfkid250's Avatar
That turbo is an HE351CW Like the others said. You can Use the internal gate or you can weld it shut. I have done it both ways. On my girl friends car (he351cw) I found an old acuator off of a dsm or something and made use of it so i dident have to buy a wastegate. It made 11psi by 5000 rpm on a stock ls (250whp). (the turbo dosent really wake up untill 15psi.)
On a HE341 I put on a D series. I welded the wastegate shut from the outside There is a machined peice of steel where the shaft goes threw. This is the best place for a weld to stick.
goodluck it will be a beast!
3easy21
Oct 27, 2012 12:09 PM
AutoLab
Jul 27, 2009 07:09 AM
turboek97
Sep 17, 2008 08:12 PM
integracivic94
Sep 3, 2006 01:52 AM
