holset hx30, spool time on d15
Old May 7, 2009 | 04:32 AM
holsetcivic's Avatar
Default holset hx30, spool time on d15
hi
i picked up a brand new holset hx30 turbo for free and i plan on piecing together a turbo kit for my civic
im putting a the hx30 turbo on my d15b7. im using a cast iron turbo mani and a 3" DP. does anyone have any hx30 experience on honda motors? what rpm range should a start building boost? between 3K-4K would be ideal but ill take what i can get.
thanks, jordan
Old May 7, 2009 | 05:01 AM
Default Re: holset hx30, spool time on d15
anyone?
Old May 7, 2009 | 05:36 AM
912's Avatar
912
your goin to love that turbo i love my hc-1 holset f@#k best bang for the buck
Old May 7, 2009 | 07:07 AM
AJxr's Avatar
post pics of it.
im assuming t3 flanged because i have seen any t2 flanged cast manifolds. do you know what size exhaust housing? i wanna see this bad boy.
Old May 7, 2009 | 02:40 PM
here are some pics of the turbo. iv researched for the housing size with no luck. does anyone elso know the housing size?
Old May 7, 2009 | 05:45 PM
90dxhmt's Avatar
It is usually stamped on the housing somewhere a number like 9,12,14,16cm etc.Should spool like 3-4 on a D i would think though.Never seen anyone really push a HX30 to see what it would make.You should measure the wheels as well.
Old May 7, 2009 | 06:04 PM
marcj's Avatar
i have a b16 12cm hx35.. spools at 5000 full boost by 6000
d15 with an 12cm hx will be crap.
If this is a street car i'd say go with a t3/t04e 57 trim or an hy35
Old May 7, 2009 | 07:10 PM
Tjabo's Avatar
HX30 is quite a different beast though I think.
Old May 7, 2009 | 09:35 PM
Boosted-EH-804's Avatar
Ouch thats rather large for a stock d15 it would do work on a built one though
Old Aug 2, 2009 | 12:19 PM
gator1's Avatar
I'm running this turbo on my 1.8 miata. Have you installed yet what are the results.
Old Apr 8, 2010 | 09:47 PM
blownhemi's Avatar
Did you eventually apply this turbo to your D15? If yes,
- ever found out the housing size (it is usually stamped into the inside of the turbine entry, one or both sides)?
- did you use a matching twin scroll manifold, or just a simple single entry?
- spool time / streetability / fun factor?
Old Apr 9, 2010 | 04:17 AM
extremeracer's Avatar
That B16 of yours seems very laggy if I compare the resluts to the DSM guys and other applications.
If you are using the stock divided t housing with a undivided manifold that will not allow the HX35 to fully shine
I know the 4G63's are 2.0 liter but they are seeing 20 psi by like 4500 even using an undivided manifold on a 12cm2 divided housing !!
and 20psi @ 3500rpm on a their 0.55 Bolt On Mitsu style housing !
Old Apr 11, 2010 | 03:17 PM
GrenadaEG2's Avatar
I have an 18cm^2 H1C on my b16 at the moment. It makes about 3-5 psi between 3500-5000 rpms. At about 5000 it starts to do its thing, spools the rest of the way and is pulling 10.5psi at about 5600.
Old Apr 12, 2010 | 01:27 PM
welfarepc's Avatar
pretty much exactly what my HE351CW did in my D16A6, except once it hit 5500-5800 it would jump from 10ish to 25 in about the blink of an eye. hahaha once it starts to go it just builds boost like a freight train!!
Old Apr 12, 2010 | 05:21 PM
slowhitEJ1's Avatar
Got a twin scroll setup on a vitara Z6 and an HX35, I hit boost around 45-4800 and 14.5 at 5-5500.. Should be about the same or a little quicker.. Is that a vband exhaust outlet? If so, what's the diameter? What is the area of the exhaust inlet? I ask because if I can find a twin scroll 9cm I'd like to pick it up... Especially since it'll spool faster than my 12..
Old May 1, 2011 | 06:53 PM
dummywheels's Avatar
I have a d16y8 build going on now im going for 250-300whp with vataras,eagle rods..
Im making some research on holsets and they seem like a good turbo for bang fot buck
i have a friend thats pointing me in the hy35 but my goal is only 250 ish so i dont want a laggy turbo im thinking more in the hx30
Hx30-hx35-hy35 wish would you go with ?
black0hatch
Jul 10, 2009 06:47 PM
slowcrxsib16
Sep 26, 2007 06:00 AM
iamthemouse
Aug 18, 2003 11:07 AM
boostedel
Nov 27, 2002 05:36 PM
Daemione
Oct 9, 2001 12:06 PM
