Need some help..cant figure out what size turbo i have
ok here is all the info i have. and i did try and search. exhaust housing says .63 on the inside of it, the inlet of the turbo is 2.75 inches, the compressore wheel has 7 blades. it came in a drag kit. im thinking its a t3/to4b. another question is is this turbo worth upgrading? it needs to be rebuilt because of lots of shaft play. just trying to hit 350 to 400 at the wheels. just dont want the turbo to fall out of the effiancy range when i up the boost. if this turbo wont put out what i want even after i upgrade it what size turbo should i go with? and one last thing if i do upgrade this turbo what should i have done? sorry for all the questions but im still learning.
Moderator in Chief
Re: Need some help..cant figure out what size turbo i have (iamthemouse)
I have the same question. Dont want to start a new topic for this.
But basically what measurements are needed to determine what turbo you have? I have a Precision T3/T04E (Im told) and want to verify that it's exactly what I ordered and not the wrong size (again).
