Holset H1B ON B16A
Old Sep 9, 2009 | 04:38 AM
b20beast83's Avatar
Default Holset H1B ON B16A
Will this turbo be too small for my b16a motor?
H1B Holset turbo, I am looking for about 400whp.
Motor is Forged with SRP Slugs
And R Cams
These are the codes on the plate of turbo
sn 739409
engine 127-0337
h1b
assy 3520851
Old Sep 9, 2009 | 06:20 AM
extremeracer's Avatar
Default Re: Holset H1B ON B16A
The best thing would be to measure the compressor wheel and Turbine wheel
For a 400whp goal on a B16 I'd say you would have to look at a H1C/Wh1C/HY35/HX35, the HX30 in theory should be able to support the HP goals with quick spool , but it hasn't been tested like the more common variants mentioned above !!
The H1C is an older, smaller version of the HX35 (with many variations) !
A H1B (following Holset naming) will probably be an older version of the HX30 or even smaller with a large exhaust housing.
I think it will be too small for your 400whp goal
Go for an HY35 if you can find one - it will be the best balance between quick spool and good flow !
Old Sep 9, 2009 | 06:37 AM
b20beast83's Avatar
a guy got the h1b for 100$
vband and ****
b16a4
Jun 25, 2007 03:51 PM
b16a4
Jun 7, 2007 05:02 PM
Mammad
Feb 15, 2003 02:54 PM
Neal_Civic
Nov 27, 2002 01:28 PM
