c02 boost control
Old Sep 8, 2009 | 07:38 PM
eulises08's Avatar
Default c02 boost control
looking for help on the co2 systems, proper way to install it, benefits, i have the bottle, the lines and the regulator. i have the turbo smart e-boost2. looking to 40+ psi on my b20 turbo setup.
any help will be greatly appreciate it.
thanks
Old Sep 8, 2009 | 07:45 PM
SPOOLINmatt's Avatar
Default Re: c02 boost control
this is really for running a low low boost off the line but using that same spring to make 40ish psi no problem right? I can't see its benefit any other way.
Old Sep 8, 2009 | 07:48 PM
eulises08's Avatar
i am using a 10 lbs spring on my wastegate.
Old Sep 8, 2009 | 07:51 PM
im just asking for the next poster....i know my 13 psi spring runs out of strength at 34 psi on a moderate temp day and it stops at 31-32 on a hot day. (on the dyno)
Old Sep 9, 2009 | 05:46 AM
TDautowerkes's Avatar
what backhousing????
when you go larger backhousing the boost will go up as well!
Old Sep 9, 2009 | 05:53 AM
eulises08's Avatar
My turbo is an s372 1.10 a/r
Old Sep 9, 2009 | 06:01 AM
same with me.
Old Sep 9, 2009 | 07:03 AM
Put a 1.25 on it.... you will get 40+ psi without Co2
Old Sep 9, 2009 | 09:39 AM
eulises08's Avatar
so d u think with 1.25 a/r, the eboost 2 and the tial 44MM i would be able to hold 40psi without any issues?
Urinemachine
May 12, 2010 01:53 PM
odishaw
Apr 1, 2008 04:37 AM
AaronJ
Mar 1, 2007 04:09 PM
White_EK49
May 24, 2005 09:46 PM
5l-eater
Oct 20, 2004 03:26 PM
