High Revs on LS
Old Jul 15, 2004 | 05:42 PM
riceburnah's Avatar
Default High Revs on LS
I have the head built on my turbo LS (dual springs,retainers,3 angle valve job), the block is completely refreshed with new ITR oil and water pump, with endyn pistons. How do change the factory limiter so I can reach my highest HP peak. Do I need a new ECU?
Old Jul 15, 2004 | 05:45 PM
roydogg's Avatar
Default Re: High Revs on LS (ihaterice8)
I would recommend Hondata , do a search on it.
Old Jul 15, 2004 | 05:52 PM
Cyphear's Avatar
You probably wont make much power past stock revline with stock LS cams, but who knows. You need to chip your ECU one way or another, I like uberdata personally. its free. http://www.ecimulti.org/uberdata.
Old Jul 15, 2004 | 07:17 PM
V3locity's Avatar
Default Re: (Cyphear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyphear &raquo;</TD></TR><TR><TD CLASS="quote">You probably wont make much power past stock revline with stock LS cams, but who knows. You need to chip your ECU one way or another, I like uberdata personally. its free. http://www.ecimulti.org/uberdata.</TD></TR></TABLE>
absolutely. The cams will be your weak point, anything is better than stock. use uberdata.
Old Jul 15, 2004 | 08:39 PM
Cyphear's Avatar
So how much power would he see from better cams at higher RPMs?
Old Jul 18, 2004 | 09:48 AM
V3locity's Avatar
cams are the weakest link in a LS head. thats where all the power will come from, stock ls cams suck!
Old Jul 18, 2004 | 09:59 AM
shermanyang's Avatar
Default Re: (SQUANTO)
don't even bother changing the factory redline yet until you've strapped your car to the dyno and know for sure that you're making power past stock redline. if you haven't done so yet...then just stick to stock for the time being.
allmotorkilla03
19
Sep 27, 2007 08:03 PM
r1ch1e
Mar 28, 2006 08:02 AM
PphamEK
Dec 15, 2005 09:20 PM
PrettyLakesBoy
Mar 19, 2005 02:04 PM
badsi21
Apr 11, 2003 12:42 PM
