High or low impedance injectors?
Old Dec 16, 2003 | 09:15 AM
1strdko's Avatar
Default High or low impedance injectors?
Which are better with Hondata, why?
All advice and suggestions are apreciated!!!!
Old Dec 16, 2003 | 12:17 PM
1strdko's Avatar
Default Re: High or low impedance injectors? (1strdko)
No one?
Old Dec 16, 2003 | 12:29 PM
ladysman's Avatar
It's not which are better. They both perform the same. If you have an OBD1 and up car, you use Saturdated injectors right out of the box as this is what the factory comes with. Although, Peak and Hold (low impedance injectors) will work if you wire in a resistor box in the factory wiring.
See here for my write up on how to do that.
https://honda-tech.com/zerothread?id=517274
Generally the bigger injectors (> than 440) will be peak and hold type although a few companies have some 550's that are saturated (High Impedance).
What car do you have?
Old Dec 16, 2003 | 12:49 PM
Muckman's Avatar
Moderator in Chief
Newer cars, use saturated injectors OBD1 + 2. The biggest saturated injectors are ~550cc from RC and will be a direct swap. Beyond that will require a resistor box to use them since they are peak and hold type injectors. Other than how they operate there is minimal pro/con to the differences as far as I know.
I asked the same question a long time ago, here is my thread.
https://honda-tech.com/zerothread?id=579490
Old Dec 16, 2003 | 06:13 PM
1strdko's Avatar
Default Re: High or low impedance injectors? (Muckman)
I have a 99 si with 450cc DSMs and Zip's SMC. I am switching to Hondata soon!
Old Dec 16, 2003 | 06:38 PM
Hoosier Daddy's Avatar
So when I do my OBD1 conversion on my CRX I can plug Peak&Hold injectors right in because my CRX comes with a resistor box stock. Correct? Also, I order OBD0 injectors right?
Thanks
b16bri
Sep 5, 2010 02:53 PM
pissedoffsol
Nov 21, 2003 11:46 AM
thejdmkid
Jul 4, 2002 02:54 PM
