high or low compression boost
Old Jul 29, 2008 | 10:28 PM
ekhatchb18's Avatar
Default high or low compression boost
hi everyone im new to honda-tech.....i have a b18b bottom end i want to boost it....ive been reading about low compression pistons and also high compression pistons with boost.....i have a set of 10.5 to 1 compression je pistons i was thinking of using them in my b18b....it has eagle rods and a fully built b18b head right now i want to put about 400whp does anyone have an idea whether to use those pistons or should i buy low compression like 8.5 to 1 compression......thanks
Old Jul 30, 2008 | 12:29 AM
xRacerX81's Avatar
its all in the tune, you could get away with using the 10.5to1's but you would be better off with 9.2 to1 pistons just to be safe...another option is a thicker head gasket like a inlinePro 3mm that will lower compression and allow you to use the je's you already have,the inlinePro gasket is expensive tho it runs 300 bucks
Old Jul 30, 2008 | 08:43 AM
ekhatchb18's Avatar
Default Re: high or low compression boost (ekhatchb18)
i bought a cometic head-gasket already...thanks for the help.....im just tryin to figure out what would be the best
Old Jul 30, 2008 | 12:10 PM
JoePSI's Avatar
You could do it, the margin for error is smaller. It will take less boost for you to hit the same goal, and your engine will have better respones out of boost but its more dangerous. I have 9.8:1 compression pistons. I had no problem hitting my goal (350-400). Just make sure you take it to a good tuner. I took mine to Mase.
If i were you I would drive to Easton to see Jeff Evans
Modified by JoePSI at 1:17 PM 7/30/2008
Old Jul 31, 2008 | 09:41 AM
ekhatchb18's Avatar
Default Re: high or low compression boost (JoePSI)
probably gonna have j-k tuning do the tune once it's built...
Old Aug 2, 2008 | 10:24 PM
ekhatchb18's Avatar
thanks for the help everyone i decided to use my high compression pistons and getting the motor built next weekend so after its done and tuned ill let everyone know what it makes....but again thanks for the input
Old Aug 7, 2008 | 10:50 PM
ekhatchb18's Avatar
ran into a new problem with the setup but also i good thing my pistons arent standard bore so does anyone know will this help or hurt me??
99siRACER
Jan 3, 2012 12:20 AM
snaileg
Nov 8, 2006 04:11 PM
blackeg
Sep 14, 2005 08:13 AM
7rrivera7
Apr 20, 2004 03:46 AM
jap-spec
Jan 16, 2003 09:35 PM
