high lift cams for boost?!?!??????
Old Feb 1, 2003 | 07:02 PM
4ghatch's Avatar
Default high lift cams for boost?!?!??????
should i get the type r or ctr cams for my b16? It will be turbo at some
point and what id like to know is will the cams be tunable with the
right gears for this motor so there is no overlap, Or should i not
get them at all
Old Feb 1, 2003 | 07:41 PM
Smashback's Avatar
Default Re: high lift cams for boost?!?!?????? (4ghatch)
Those should work fine with turbo, just get the cam gears. High lift is fine for turbo, duration is what kills you. Similar to stock duration and higher lift works great.
Old Feb 1, 2003 | 08:31 PM
boosted hybrid's Avatar
If you are really looking at spending the money on cams, then check out either skunk2 or rocket's turbo cams. You can see rocket's cams at http://www.ef-1.com. Cams should be one of the last things you get for your boosted engine. You can make very good power with the stock cams, just by adding cam gears. I believe the main purpose with a turbo cam is to extend the torque curve, and yield a modest increase in hp.
Old Feb 2, 2003 | 04:43 AM
BudaKai's Avatar
Default Re: high lift cams for boost?!?!?????? (boosted hybrid)
I was looking at those ef-1's then I noticed they do custom for the same price.
Old Feb 2, 2003 | 07:51 AM
Savalicious's Avatar
I have great luck with Crowers Turbo cams, you always need gears though to real help tune your power curve.
Old Feb 2, 2003 | 08:22 AM
Default Re: high lift cams for boost?!?!?????? (quick1723)
Have you had breakage on the crowers? I have been hesitant to even look at them since the horror stories of their dohc vtec cams awhile back.
Old Feb 2, 2003 | 08:54 AM
earl's Avatar
You must use Type R lost motion sensors and ask for a smaller base circle to be ground into your cam. These two steps will stop any cam from breaking, even Crower.
Old Feb 2, 2003 | 10:32 AM
Default Re: high lift cams for boost?!?!?????? (earl)
Earl,
I am kinda fuzzy on cam stuff. What does "a smaller base circle to be ground into your cam" mean exactly? What exactly does the lost motion assembly do?
Old Feb 2, 2003 | 11:36 AM
boosted3g's Avatar
smaller base circle means that the area of the cam that has the valve closed has a smaller diameter. Its sort of hard to explain. For instance if you use a stock cam and then use a cam with a smaller base circle your valve lash will increase because of the smaller base circle. Most of the time you request smaller base circles if you have done a few valve jobs on a head and the valves are "sunken" into the head a little further than normal. I konw its no the best definition but do you get the idea
Old Feb 2, 2003 | 12:06 PM
Quick 200k Mile Motor's Avatar
Default Re: high lift cams for boost?!?!?????? (boosted3g)
interesting!
So a valve job can sink valves so much that you'll need smaller base circle cam to keep the valve closed..
Old Feb 2, 2003 | 09:08 PM
earl's Avatar
Default Re: high lift cams for boost?!?!?????? (Quick 200k Mile Motor)
interesting!
That why you have adjustable valve lash, to put everything back to stock.
Old Feb 2, 2003 | 09:36 PM
MotorMatrix.com's Avatar
I am a bad person
i have always run my type r cams with stock gears and havent had any problems. i'm not sure what my limit will be but i havent had trouble making power yet. anyone think 650-700whp will be a problem with type r cams and stock gears??
Spawne32
Oct 22, 2010 03:11 PM
9341civic
Jun 1, 2005 12:31 PM
MysteriousGSR
Feb 2, 2003 09:03 AM
CimorelliCRX
Jul 27, 2002 02:04 PM
Black Sheep
Jun 21, 2002 06:59 AM
