vtec turbo cams
Old May 31, 2005 | 06:18 PM
9341civic's Avatar
Default vtec turbo cams
people on here say gsr cams or itr cams what about aftermarket like skunk2 turbo cams or crower 63401t? why go with oe cams when these companies spend time on r&d
Old May 31, 2005 | 08:26 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: vtec turbo cams (9341civic)
Price.
If you use NA cams, get some cam gears so you can get rid of overlap so you don't blow your equalizer juice out the muffla.
Old Jun 1, 2005 | 02:18 AM
mrx's Avatar
mrx
Default Re: vtec turbo cams (2000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000psi &raquo;</TD></TR><TR><TD CLASS="quote">Price.
If you use NA cams, get some cam gears so you can get rid of overlap so you don't blow your equalizer juice out the muffla.</TD></TR></TABLE>
Do you want to say that aftermarket turbo cams like the crower + cam gears aren't better then i.e. GSR cams+Cam gears?
or are here advance in power with both, crower turbo cams AND cam gears?
Best gegards
Malte.
Old Jun 1, 2005 | 12:31 PM
2000psi's Avatar
Default Re: vtec turbo cams (mrx)
Of course well designed aftermarket cams will blow away OEM cams.....I'm just saying people use OEM cams because they will work very well for %85 of the turbo setups here, plus, they are already in your engine.
The focus should be to minimize overlap on turbo streetcars....although on race engines boost+overlap= crossover madness and makes a ton of power.
evilk
May 29, 2005 06:01 PM
slowkaos
Dec 12, 2004 07:23 PM
Old_Honda
Jun 25, 2004 07:53 PM
TurboGSR00
Jan 4, 2004 01:25 AM
Black Sheep
Jun 21, 2002 06:59 AM
