high egt's running rich?
Old Jul 13, 2002 | 01:04 PM
syeve's Avatar
Default high egt's running rich?
just curious what else could be causing my high EGT (1000 under no boost), Im not running lean...what else could it be?
Old Jul 13, 2002 | 02:43 PM
jamal-188's Avatar
Default Re: high egt's running rich? (syeve)
High egt's ususally mean running lean, low egt's=running rich.
Old Jul 13, 2002 | 03:14 PM
DSF's Avatar
DSF
Is that 1000*F or *C? I'll assume (and I hope for your sake) it's *F. These are the average temps I've gathered from previous posts...
idle...650*F-850*F
cruise around town...850*F-1150*F
highway...1250*F-1500*F
boost @WOT...no more than 1450*F-1500*F
Generally your peak EGT reading will occur at a stoich ratio (@14.7). As you go richer OR leaner, the EGT wil drop (ie. get cooler). However, an overly rich mixture will cause high EGT readings as well as some of the unburned mixture will ignite in the hot exhaust manifold. Also, retarded ignition timing is another cause for high EGT readings.
Old Jul 13, 2002 | 03:33 PM
93LSivic's Avatar
Default Re: high egt's running rich? (jamal-188)
Just the opposite. If your running rich then you will have higher egt's. The unburnt gas actually ignites in the exhaust manifold, causing higher egt readings.
Kazz
Apr 30, 2003 01:08 PM
IloveNewt
Mar 1, 2003 04:54 PM
CiViC SiR
Jan 29, 2003 01:52 PM
shamoo
Sep 30, 2002 06:38 AM
