High Compression(PSI?)
Old Jul 17, 2006 | 11:17 AM
stockb18c's Avatar
Default High Compression(PSI?)
I have a B18C 10.6 to 1 compression how much PSI can i get out of it until it goes KABOOM!!! With stock internals...in goin to have 450cc injectors and tuned on crome pro
Old Jul 17, 2006 | 11:39 AM
scB20teg's Avatar
Default Re: High Compression(PSI?) (stockb18c)
300whp is doable with good tuning. Get a thicker head gasket to lower the compression a little if you can.
Old Jul 17, 2006 | 03:36 PM
purpleh22's Avatar
Default Re: High Compression(PSI?) (scB20teg)
Do you have an intercooler? Alcohol/water injection can also help you get more reliable horsepower. 300 whp seems like it might be close to the edge without either of the above.
Also (scB20teg) who would you recommend for the tuning in the Portland area?
Old Jul 17, 2006 | 06:10 PM
eastbay92cx's Avatar
Default Re: High Compression(PSI?) (purpleh22)
b18c with stock internals about 190psi if the motor's in good shape...
but seriously like the others said ~300whp should be relatively safe (and about the limit of those injectors) with a gt28rs or a smaller t3/t4... good luck
Old Jul 17, 2006 | 08:23 PM
quicksilver1689's Avatar
i ♥ snails
Yeah like dtated above go with a semi smaller turbo so u can use it across the whole powerband. Gt28 is a good choice the response will be nice and it will pull alltheway through the topend
jtracing919
Jan 26, 2006 12:15 AM
CRXLST
Sep 23, 2004 08:41 AM
Reedy
Mar 30, 2004 10:02 PM
ucantcatchmefoo
Feb 24, 2004 09:18 PM
swlabhot
May 13, 2003 07:58 AM
