High Compression and boost
Old Aug 24, 2003 | 05:56 AM
TTWS6.
Guest
Posts: n/a
Default High Compression and boost
Who here has been running a Built or stock High C/R turbo motor on Hondata? I mean anything north of 9:8:1 I want to know..
1 What motor
2 what Octane gas do you use daily?
3 how much boost
4 what spec turbo
5 spool time
6 Air/fuel ratio @ WOT and @crusing speeds
7 EGT's over 75 mph @ WOT
8 how much advanced timing @ WOT
9 and how long has your setup been running trouble free.
sorry for the PITA questions
Old Aug 24, 2003 | 07:14 AM
JSMC's Avatar
Default Re: High Compression and boost (TTWS6.)
don't be worry, I wanna know it too
Old Aug 24, 2003 | 07:27 AM
Soon_2b_evil's Avatar
Default Re: High Compression and boost (JSMC)
I'll let you guys know when im done
Old Aug 24, 2003 | 01:31 PM
TTWS6.
Guest
Posts: n/a
Default Re: High Compression and boost (Soon_2b_evil)
anyone ?
Old Aug 24, 2003 | 02:01 PM
hybrid901's Avatar
1 What motor -84.5mm gsr
2 what Octane gas do you use daily? -93 under 14psi, c16 up to 24psi
3 how much boost
4 what spec turbo-sc61
5 spool time-24psi around 4600rpm
6 Air/fuel ratio @ WOT and @crusing speeds -WOT 11.5-12.2
8 how much advanced timing @ WOT- 20 degrees
9 and how long has your setup been running trouble free. 4mos
Old Aug 24, 2003 | 02:21 PM
ekb18c's Avatar
1 What motor - b18c, 81mm 426WHP @ 21 psi
2 what Octane gas do you use daily? 94 octane with 14.7 psi.. c16 on anything higher (Daily Driver)
3 how much boost -
4 what spec turbo - 62-1, P-trim, .72 a/r
5 spool time - Full Boost @ 5k.
6 Air/fuel ratio @ WOT and @crusing speeds - WOT 12.5
7 EGT's over 75 mph @ WOT -
8 how much advanced timing @ WOT -
9 and how long has your setup been running trouble free. - 1 year
Old Aug 24, 2003 | 02:40 PM
-iLLuZioN-B18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TTWS6. &raquo;</TD></TR><TR><TD CLASS="quote">Who here has been running a Built or stock High C/R turbo motor on Hondata? I mean anything north of 9:8:1 I want to know..
1 What motor
3 how much boost
4 what spec turbo
5 spool time
would it not be helpful if you included the question.
10) what CR are you running?
sflemon
Jun 22, 2011 02:11 PM
Boost2NA
Sep 30, 2003 02:55 AM
1.8T_EG
Oct 25, 2002 02:46 PM
pkripper
Apr 30, 2002 08:05 PM
slowcivic
Dec 14, 2001 10:12 AM
