high comp/low boost vs lower comp/high boost
Old Jan 5, 2006 | 03:13 PM
  #26
93supercoupe's Avatar
Default Re: high comp/low boost vs lower comp/high boost (my crx is rhd)
It baffles me that u guys are speaking of PSI levels but have yet determined what turbo u will be using.If u havent figured it out yet, PSI means nothing w/o the turbo size.
Old Jan 5, 2006 | 03:44 PM
  #27
GaRn's Avatar
Default Re: high comp/low boost vs lower comp/high boost (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">It baffles me that u guys are speaking of PSI levels but have yet determined what turbo u will be using.If u havent figured it out yet, PSI means nothing w/o the turbo size. </TD></TR></TABLE>
Thats a given, he will probably use a common t3/t4 on the smaller side, just guessing since he mentioned low psi numbers and its gonna be a street car..
That really doesn't have much to do with it though, considering he would use the same turbo on each setup..
Old Jan 5, 2006 | 09:21 PM
  #28
machine4321's Avatar
opps i though i put it in there .
3 ive been thinking of
t3 60-1 (can get a good deal on it
t3/t4 57 trim
i tihnk the last one i though about was the sc34 or sc50 i forget with one
Old Jan 5, 2006 | 09:39 PM
  #29
kameleon23's Avatar
Default Re: (machine4321)
I have an idea! Buy 2 Hi comp pistons and 2 low comp pistons
Old Jan 6, 2006 | 12:53 AM
  #30
Tony the Tiger's Avatar
Regardless of turbo size, a higher static compression will make more power at the same PSI. Key is to make the best power safely with higher compression based on octane and power levels. You simply do not need to drop down to 9.0:1 CR with 400WHP and premium gas (ie: 93 oct).
Old Jan 6, 2006 | 01:07 AM
  #31
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my crx is rhd &raquo;</TD></TR><TR><TD CLASS="quote"> i agree with that....lag isnt there if your setup correctly....i guess you can say what some people call lag, could be considered before your powerband....so rather than make power from 2500- 7000 maybe its 4000-9000rpm's.....if you think about it </TD></TR></TABLE>
You gotta teach me how to build a correct setup so I can have a lag-less turbo Honda There will be lag regardless how good the setup is for a puny 2.0L 4-cyl engine reaching 300+ WHP. It's up to how the person feel about the lag. Knowing that machine4321 is coming from an all motor ITB setup, he's going to hate lag as much as I do.
Power-band is one thing, but people are really confused about RPM spool time, boost response and throttle response. These are three completely different things and you can't mix them up. Higher compression would benefit throttle response and power before boost hits. Turbo sizing would mostly dictate what type of RPM-range the power comes in. Changing the compression will not make the engine's powerband run at a lower RPM range or vice versa.
Old Jan 6, 2006 | 06:41 AM
  #32
FATBOYeg6's Avatar
Default Re: high comp/low boost vs lower comp/high boost (Tony the Tiger)
tony, out of curiosity, what is full boost on your setup (the 10.5:1 comp)? when do you hit full boost in say 3rd gear? and last, do you have a dyno? i have a friend who has a similar setup to yours (28rs, and 10.3:1 comp) that i would like to compare it to.
Old Jan 6, 2006 | 09:10 AM
  #33
GaRn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">opps i though i put it in there .
t3/t4 57 trim
i tihnk the last one i though about was the sc34 or sc50 i forget with one </TD></TR></TABLE>
I have a t3 60 trim on my H23(its a from a nissan 300z single turbo), and it does pretty well, but maxes out at around 250-300 whp generally..
I have full boost at around 2700 rpms and it starts to spool around 2,200, in 3rd gear, and it pushes all the way up to 7,200 without dropping off, definitely gives a good torque curve as you can see..
(this dyno is only on 3.8 psi)
If I were you I would go ahead and go with the t3/t4 57 just for a bit more punch up top..
Old Jan 6, 2006 | 07:47 PM
  #34
the 60-1 is alot bigger then the t3 60
its bigger then the t3/t4 i think to .
Old Jan 7, 2006 | 07:59 AM
  #35
Default Re: high comp/low boost vs lower comp/high boost (ninefivehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninefivehatch &raquo;</TD></TR><TR><TD CLASS="quote">tony, out of curiosity, what is full boost on your setup (the 10.5:1 comp)? when do you hit full boost in say 3rd gear? and last, do you have a dyno? i have a friend who has a similar setup to yours (28rs, and 10.3:1 comp) that i would like to compare it to.</TD></TR></TABLE>
3rd gear, I would say the GT28RS made about 8-9 psi at 3500-3700RPM. I have dyno for a 8 PSI run, but I didn't scan it and put it in the computer. It made 286 WHP and 245 lb-ft but boost was dropping back to 6-7 psi after 7500RPM which was later solved.
Old Jan 8, 2006 | 10:13 AM
  #36
GaRn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">the 60-1 is alot bigger then the t3 60
its bigger then the t3/t4 i think to .</TD></TR></TABLE>
hmm what are specs on the 60-1?
MyEvo
Oct 6, 2005 05:14 AM
ludelvr
Nov 25, 2003 02:09 PM
VanHonda
Nov 9, 2003 06:42 PM
ringgold
Nov 5, 2003 02:21 AM
rb08
Aug 26, 2003 07:52 AM
