Hey turbo spec guru's..... selection help!
For a 1650cc built D16 revving to about 8k, which would you select for best drivability + 400whp capability:
http://store.yahoo.com/cheapturbo/gart3w63artu.html- T3/60-1- 76 trim wheel (what would this relate to in "stage" size?) .63 A/R turbine / 60trim .70 A/R comperssor
or..
http://store.yahoo.com/cheapturbo/gart3to460tr.html - T3/T04E- Stg 3 .63 A/R turbine/60 trim .60 A/R compressor (my original plan)
Both turbines are .63 A/R but the 60-1 uses a "76 trim wheel" vs. the T04's Stage 3 wheel. I get them impression the .70 A/R 60 trim 60-1 compressor will flow more air in the upper end, but how much slower would you think spool time would be for that turbo?
or..
on me for not pointing that out on the site..these turbos both use the exact same turbine housing and wheel. the major differences of these 2 being that the centersection on the t3/60-1 comes factory with 360* thrust bearings and the to4s housing wiht the 60-1 wheel will flow a larger volume of air.
I get the impression the .70 A/R 60 trim 60-1 compressor will flow more air in the upper end, but how much slower would you think spool time would be for that turbo?
i would honestly suggest the t3/to4e for the d-series for street drivability
hope this helps
Considering the size of your motor and the fact that you want it to be a good daily driver, I'd suggest the T3/T04E. You'll find plenty of power, and have a good spooling turbo.
So 76mm = stg 3 wheel, thanks dude
It's not really going to be a daily driver, I have 2 others cars for that, but I do want to maintain a sense of drivability, kinda like what Karl had with his Civic i.e. street legal track car
But yea, I think the T04E would probably suit this motor best too, I just wanted to throw that out there and get some more opinons, thanks guys.
Joe- soon enough buddy, soon enough heh
underpressure02
Feb 10, 2004 07:26 AM
