help with turbo setup...
Old Oct 20, 2004 | 09:38 AM
tig3rxiong's Avatar
Default help with turbo setup...
im currently in the process of buying turbo parts for my setup. i have so far...
-t3 turbo
-drag manifold
-drag downpipe
-intercooler
-piping
i know i need to have the following...
-bov
-wastegate
my question is, do i need some other stuff? im planning on using walbro fuel pump. are there anything else i need to buy to use the walbro pump? would i need a new ecu, and injectors? i would not want to do hondata because i dont know how it works and what to buy for it.
please dont flame me , and yes i did try to search but couldn't find what i was looking for. whats that one website where they showed pictures of turbocharged gen2 integras? it also showed and gave information about each part on a turbo setup.
Old Oct 20, 2004 | 10:17 AM
tig3rxiong's Avatar
anyone? please help
Old Oct 20, 2004 | 10:48 AM
PrettyLude's Avatar
you need the return and feed lines, some type of fuel management
Old Oct 20, 2004 | 10:56 AM
Nikoli's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">you need the oilreturn and feed lines, some type of fuel management
</TD></TR></TABLE>-dont forget the nipple on the oil pan
you'll need an FMU and an safc since you dont want hondata.
get the install kit with the walbro.
injectors
boost gauge, egt, oil press, etc...
i assume your running no more than 7psi?
Old Oct 21, 2004 | 07:50 AM
tig3rxiong's Avatar
correct. im planning on boosting only 7, the least 6 until i build up my block. so i would need...
-FMU
-Walbro
-Injectors
-Gauges
-SAFC
now another question...how many kind of FMU is out there?
thanks in advance
Old Oct 21, 2004 | 08:05 AM
S-fiend's Avatar
Default Re: (tig3rxiong)
Greedy sells their E-Management unit for like $250-300
They come with their turbo kits preprogrammed but since your buying the unit you'll need to program it for you application.
Maybe you can contact them and see if they can send you one programmed for the kit they sell for your car. But then you'll need to be running a VERY similiar setup as them.
**** it. Take it to a shop to get it tuned on the dyno.
Hondata K-pro would be the absolute best way to go, with proper tuning. Hand your car over to some pros and about 50 pulls later your car will run perfect.
Old Oct 21, 2004 | 05:05 PM
tig3rxiong's Avatar
if i do go hondata. will i need a new ecu? what other parts are required for hondata?
Old Oct 21, 2004 | 07:11 PM
jdm91integ's Avatar
Default Re: help with turbo setup... (tig3rxiong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tig3rxiong &raquo;</TD></TR><TR><TD CLASS="quote">whats that one website where they showed pictures of turbocharged gen2 integras? it also showed and gave information about each part on a turbo setup.</TD></TR></TABLE>
http://www.beesandgoats.com/bo....html
Old Oct 21, 2004 | 07:23 PM
tig3rxiong's Avatar
thx for the reply!
andreysibiris
13
Jan 17, 2006 12:03 PM
Boosteddc2gsr
Feb 2, 2005 09:20 PM
AznPrideYo
Jan 28, 2004 09:54 AM
mamaboy
Oct 10, 2002 03:27 PM
SiRkid
Jul 3, 2001 07:00 PM
