b18c1 turbo set up, what to do what to do
I have a stock b18c1 (gsr) in my 96 civic hatch. I recently purchased a rev hard turbo mani which allows me to use ac and I do plan on keeping. I bought a garrett t3 ar48 "super 60" quick spooler. The turbo comes with a internal wastegate and has a dumptube, also this turbo has both oil cool and water cool. I dont see how I can use this set up, the reason why I say that is because the intercooler piping looks like it wont wont connect with the turbo? Im not a turbo expert but i'll try to explain what I mean, theres 2 openings on a turbo, 1 opening you can see the fan blade? and the other opening is where my problem is, Its facing my engine block. Does this make any sense? I seen other turbos where the 2nd opening I mentioned is facing down or away from the block and allows IC piping to work? Can I adjust the position of my turbo or somthing? Need some more info but this is my main concern at this moment some please help
Re: b18c1 turbo set up, what to do what to do (EK project hybrid)
yes u can reposition the turbo by loosing the bolts that clamp the compressor and turbine housing on...make sure that the center section has the oil feed inlet stright up and oil return down...
Re: b18c1 turbo set up, what to do what to do (B20luda)
Thanks for the help guys, I didnt know the responces would come in so quick. Here is a link to the turbo I have, sorry I cant post pic.
http://cgi.ebay.com/ebaymotors...24197
Is a internal wastegate better then external? Also how would i adjust this internal wastegate if i were to keep it?
Re: (lanojp1)
im new at this turbo scene, i need to learn and learn asap. so far the info you guys gave me sounds useful. Does any1 have pics of there turbo set ups?
FBPSidan
11-17-2003 08:30 AM
