HELP: turbo kit on 1990 civic hatch DX
it has 1.5 dual point motor with only 2 injectors, do i just get 2 bigger injectors or do i have to switch intake manifolds to have four injectors???? i only will be running 6psi.
if i need to switch intake manifolds, what all is required to do this???
Re: (98TEG2NV)
DPFI sucks for performance..Technically you could get extra injectors and plum them into the intake somehow and get an aic controller to add extra fuel ,,but why bother..? Just do the mpfi convsersion and get a chippable pm6 and run turbodedit to tune it when you put on the turbo setup..
o well the car isnt mine, its a friend of mine and hes on a low budget thats why i wanted to know if i could just put the turbo kit on with out changing the manifolds and everything
