HELP! Turbo install complete, yet no boost!!!
Old Jul 17, 2002 | 11:55 PM
zojirushi's Avatar
Default HELP! Turbo install complete, yet no boost!!!
Ok, i just finished this forsaken install. And i take it out for a spin, **** is mad loud... yet NO BOOST!!!!! no bov sound, and the car feels really sluggish. I can even hear the damn turbo spool up. Any suggestoins?
I checked for leaks in my piping, couldn't find any...
[Modified by zojirushi, 3:56 AM 7/18/2002]
Old Jul 17, 2002 | 11:58 PM
B20-T's Avatar
Default Re: HELP! Turbo install complete, yet no boost!!! (zojirushi)
check for leaks..vacum leak or anything..ic pipes
Old Jul 18, 2002 | 12:03 AM
zojirushi's Avatar
Default Re: HELP! Turbo install complete, yet no boost!!! (B20TURB0)
i check... everything is clear.
Old Jul 18, 2002 | 12:06 AM
inspyral's Avatar
is your wastegate sealing?
Old Jul 18, 2002 | 12:10 AM
zojirushi's Avatar
Default Re: HELP! Turbo install complete, yet no boost!!! (inspyral)
sealing as in on the manifold.. if so , yes
Old Jul 18, 2002 | 12:18 AM
zojirushi's Avatar
Old Jul 18, 2002 | 12:25 AM
zojirushi's Avatar
new note.... i have a 1g dsm bov. at idle, theres air coming out... that bad????
Old Jul 18, 2002 | 12:33 AM
ceemarun's Avatar
if im not mistaken, if air is leaking when its at idle, it means youre leaking boost too.......i wouldnt be too sure of myself though, butt search into stuff about leaking BOV's.....im sure it has something to do w/ it. keep up w/ the install!
Old Jul 18, 2002 | 12:36 AM
VaporTrail's Avatar
New User
Default Re: HELP! Turbo install complete, yet no boost!!! (ceemarun)
check to make sure your wastegate is working properly, and that all of your vaccum lines are routed and functioning properly.
Old Jul 18, 2002 | 01:44 AM
Mr. Softee's Avatar
Default Re: HELP! Turbo install complete, yet no boost!!! (VaporTrail)
all IC piping hooked up
Old Jul 18, 2002 | 02:02 AM
rjardy's Avatar
i think that may be your problem, dop you ahve another BOV that you could try?
Rob
Old Jul 18, 2002 | 03:59 AM
Mike@Altered's Avatar
Sounds like the problem.. Try another bov, I bet you'll have boost.
You also mentioned a loud sound, sometimes its a good idea to re-torque the manifold bolts, turbo to manfiold bolt, and wastegate bolts after the car is started (warmed up) to make sure everything is sealed 100%.
Hope this helps,
Old Jul 18, 2002 | 07:33 AM
RGAZ's Avatar
New User
Try removing the BOV compeltely and plugging the opening.
If you get boost then, the BOV is too leaky.
Don't drive too long that way, no BOV is hard on the turbo.
Randy
Old Jul 18, 2002 | 11:32 AM
Etylorcen's Avatar
Default Re: HELP! Turbo install complete, yet no boost!!! (RGAZ)
Check your fmu...is it on reverse? Check all the charge piping. Make sure your wastegate is on tight.
Old Jul 18, 2002 | 02:17 PM
MiraiZ's Avatar
Little Tial wastegate ring?...was it installed??
Old Jul 18, 2002 | 04:56 PM
OKSolSi's Avatar
Default Re: HELP! Turbo install complete, yet no boost!!! (MiraiZ)
I have the answer for you my friend. The eclipse BOV that you are using is prone to leak, and it is your problem. Most people run a "crushed" Eclipse BOV. You take off the BOV from the flange, lay it flat on the ground, and smash the top in with a hammer. I have the same blowoff valve, and I don't know why or how, but crushing it, within reason, stops the leak. Don't go postal and smash it flat though - just slightly and your problem should be fixed.
Old Jul 18, 2002 | 06:08 PM
KC GSR's Avatar
Default Re: HELP! Turbo install complete, yet no boost!!! (OKSolSi)
This is what I do to broken computers. It works really well
Old Jul 18, 2002 | 07:02 PM
Jared's Avatar
Default Re: HELP! Turbo install complete, yet no boost!!! (KC GSR)
It is normal for the bov to leak at idle, that isnt the problem. The bov is seeing vacuum from the manifold at idle and therefore is open. sounds like you have a charge pipe loose or a sealing surface that isnt together(manifold to head or manifold to turbo)
Old Jul 18, 2002 | 09:54 PM
shadowdawn's Avatar
Default !
Will call me up, I'll help you fix this ****, I know you've been trying to be boosted for a while now We'll figure it out!!!!!!!! MUST HELP A ANOTHER AUTOMATIC GET BOOSTED!! GOAAAAAA!
Old Jul 19, 2002 | 12:25 AM
Duck Sauce's Avatar
Default Re: ! (shadowdawn)
Do you have a boost gauge? That would help a lot. And yeah, get rid of that DSM BOV. DSM BOV's are prone to leak. Get a Blitz or something.
Old Jul 19, 2002 | 04:34 PM
zojirushi's Avatar
Default Re: ! (DC2ownz)
ok, how do i check for leakage in my piping??? i can't really think of a way. I'm gonna test out this bov theory crap... but i dunno... Thanks for all your suggestions. I'll keep everyone updated
evilsolb16
Jun 7, 2007 12:37 PM
hybrid_204
Sep 5, 2005 08:24 PM
1.8EG-T
May 15, 2005 02:52 PM
T3EMSI
Sep 7, 2002 04:27 AM
