Help on a turbo charger please!
Old Jan 3, 2003 | 11:42 AM
youngkow's Avatar
Default Help on a turbo charger please!
I just recieved my t3/t4 for the custom turbo I'm doing, but the outlet of the compressor is facing the block. Can I disassemble the turbo and rotate the housing so that the outlet faces downward? Also, should the oil return be facing up or down? Thank you.
Old Jan 3, 2003 | 11:43 AM
CzanSOHC's Avatar
Default Re: Help on a turbo charger please! (youngkow)
You need to "clock" the turbo, just unbolt it and move to the postion you need. The return line should ALWAYS be facing down, it uses gravity to drian.
Old Jan 3, 2003 | 11:46 AM
BlueShadow's Avatar
Default Re: Help on a turbo charger please! (CzanSOHC)
to be more specific you need to loosen (dont remove) the 6 bolts on the backside of the compressor housing. Once you've loosened the 6 bolts the compressor housing should be able to rotate. Once it's in the right position just remember to tighten the 6 bolts back up.
[Modified by BlueShadow, 12:47 PM 1/3/2003]
Old Jan 3, 2003 | 11:56 AM
youngkow's Avatar
Default Re: Help on a turbo charger please! (BlueShadow)
Thanks guys! I hope to be boosted soon! woooOOHooooOOOO!
Forgot to ask, can I loosen the turbine side bolts too? Thanks again.
[Modified by youngkow, 2:57 PM 1/3/2003]
Old Jan 3, 2003 | 12:02 PM
CzanSOHC's Avatar
but if his center section is upside down(like mine) I had to remove the bolt and flipt everything around.
Old Jan 3, 2003 | 12:03 PM
BudaKai's Avatar
Just makes sure you tighten them good... I saw someonepansy them tight, and boy that was a mes when he drove it. The center section fell out and shattered the compressor blades. I just couldn't stop laughing.
Excelerate
Aug 17, 2006 10:51 AM
pro547
Jun 20, 2005 12:54 PM
ID_ten_T
Aug 22, 2004 12:29 PM
Spoold_R
Feb 12, 2004 08:14 AM
HondaCutter
Sep 6, 2002 12:28 PM
