DSS axles and ABS
Old Apr 17, 2004 | 10:09 PM
Bnjmn's Avatar
Default DSS axles and ABS
I have a set of Drive Shaft Shop Stage 3 axles with ABS rings on them.
The only problem is that the ABS rings are about 1/4" off from being under the ABS sensor. The edge of the sensor is about even with the edge of the ABS teeth, but there is no overlap and the sensor puts out a very weak signal when a wheel is turned.
Anyone else have this problem? Any suggestions?
Thanks
Ben
Old Apr 21, 2004 | 07:41 AM
cheezoto's Avatar
Default Re: DSS axles and ABS (Bnjmn)
i would contact DSS on this, but since the rings are removable i think you could slide it in the direction it needs to go
AznBlueBoy
Jul 16, 2009 10:53 AM
shortycm17
Dec 26, 2007 03:31 PM
SimplyTron
Nov 5, 2006 12:30 PM
charjacq
Mar 2, 2003 09:21 AM
ILOVEGIRLS
Mar 27, 2002 08:36 PM
