Help!! strange timing question...
Old May 3, 2003 | 04:24 PM
GruvyTune's Avatar
New User
Default Help!! strange timing question...
I'm trying to troubleshoot a timing problem for a friend with a GSR.
No matter what he does, he cant get the timing to advance more than 12 degrees.
I had him recheck his cams and crank and they line up perfectly.
idle is at 800 with an aftermarket TB.
any ideas on what else could be wrong?
Old May 3, 2003 | 05:06 PM
Trac226's Avatar
Default Re: Help!! strange timing question... (GruvyTune)
Have you tried checking the tps?
Old May 3, 2003 | 05:21 PM
Mase's Avatar
is it the same pulley?
Old May 3, 2003 | 05:33 PM
GruvyTune's Avatar
New User
Default Re: Help!! strange timing question... (Mase)
i can only assume the motor was taken apart and put back together with the same pulley.
he has his mechanic looking it over right now.
Old May 3, 2003 | 05:34 PM
GruvyTune's Avatar
New User
Default Re: Help!! strange timing question... (Trac226)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trac226 &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried checking the tps?</TD></TR></TABLE>
the tps will not affect timing. certainly not retard it like that.
Modified by GruvyTune at 10:10 PM 5/3/2003
Old May 3, 2003 | 07:38 PM
BrokenVtec's Avatar
any help would be greatly appreciated.....
Old May 3, 2003 | 08:15 PM
boosted hybrid's Avatar
Default Re: Help!! strange timing question... (BrokenVtec)
If I am understanding the question right, you could have possibly skipped a tooth on the timing belt. I had this happen to me, and i couldnt get the timing to go past 8 degrees no matter how much I adjusted the distributor.
Old May 3, 2003 | 08:26 PM
BrokenVtec's Avatar
Default Re: Help!! strange timing question... (boosted hybrid)
triple checked it....
Old May 3, 2003 | 08:44 PM
Arturbo's Avatar
Better than steak
25 Year Member
I had a friend that couldnt get the timing past 5deg. and told us all the time, I double checked it. But what did we find out a few months later? It had jumped a tooth.
art
Old May 3, 2003 | 10:10 PM
DaveF's Avatar
if the cyl head was milled down alot, could this pose a problem?
Old May 3, 2003 | 10:16 PM
slowsi00's Avatar
Default Re: Help!! strange timing question... (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">if the cyl head was milled down alot, could this pose a problem?</TD></TR></TABLE>
i would imagine so
Old May 3, 2003 | 10:51 PM
BrokenVtec's Avatar
Default Re: Help!! strange timing question... (slowsi00)
head was never milled
Old May 4, 2003 | 05:09 AM
GruvyTune's Avatar
New User
Default Re: Help!! strange timing question... (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">I had a friend that couldnt get the timing past 5deg. and told us all the time, I double checked it. But what did we find out a few months later? It had jumped a tooth.
art</TD></TR></TABLE>
I keep insisting the same thing, timing belt off a tooth. Had another person this happened to and turned out to be the same. As brokenvtec said, he checked it yesterday, so i have to assume he and his mechanic know to check that. Thats why i'm a bit dumbfounded about it at this point.
Old May 4, 2003 | 05:16 AM
Arturbo's Avatar
Better than steak
25 Year Member
I will also say it took 4 pair of eyes to finally see it.
art
Old May 4, 2003 | 05:25 AM
GruvyTune's Avatar
New User
agreed,
they need to quadruple check it then. i know its a pain in the *** but it needs to be corrected.
Old May 4, 2003 | 07:21 AM
BrokenVtec's Avatar
bump....i am checking everything again today
Old May 4, 2003 | 01:37 PM
BrokenVtec's Avatar
re did everything then nothing, then swaped hondatas with a friend of mine (very similar setup) and installed his injectors and the same point where my timing was at 12.....with his setup was 24 degrees....
Old May 4, 2003 | 01:49 PM
SiRkid's Avatar
weird
Old May 4, 2003 | 01:51 PM
BrokenVtec's Avatar
Default Re: Help!! strange timing question... (SiRkid)
tell me about it... could it be corrected with further tuning...??
Old May 4, 2003 | 02:34 PM
GruvyTune's Avatar
New User
it is interesting. i set the base timing in the Romeditor to match what his base timing was. the only thing could be that your friends chip is set for a different base timing or his tuner put tons of advance on his chip. Your base timing is quite retarded so we are starting our ignition curves from that baseline.
you will be trying a stock ecu as i suggested to see if the stock computer still shows a lot of retarded distributor timing.
Old May 4, 2003 | 04:46 PM
BrokenVtec's Avatar
i tried...but didnt start.... and i was too tired to take the injectors back out to put stock ones in
Old May 5, 2003 | 09:20 AM
earl's Avatar
I'm not a tuner (and can't even pretend to be one) but I think there is a program somewhere in the computer that is electronically moving the timing back to a predetermined (programmed) maximum amount. You could set the distributor to 80 degress advance and it is brought back to spec electronically.
Old May 5, 2003 | 09:58 AM
Sonny's Avatar
Are you running a stock OEM distributor? I've heard of people having problems like this with rebuilt Autozone units.
Sonny
Old May 5, 2003 | 10:23 AM
BrokenVtec's Avatar
Default Re: Help!! strange timing question... (Sonny)
completely stock distributor with the msd cap.... today i am swapping in stock injectors and a stock ecu to try to determine the problem a bit more
wcpreston
Nov 29, 2016 10:32 PM
KURUPTinc
21
Nov 25, 2011 01:44 AM
JDMTurboCivic11
May 1, 2005 08:32 PM
CIVIC96DXcp
Apr 19, 2005 07:47 PM
GruvyTune
May 3, 2003 07:51 PM
