Help with strange noise with built b16a2
Old Jul 29, 2009 | 09:11 AM
joppe's Avatar
Default Help with strange noise with built b16a2
http://www.youtube.com/watch?v=XdqqQiMJ_g0
http://www.youtube.com/watch?v=Wt6YOFakNPg
http://www.youtube.com/watch?v=uQu8Q3mcCqg
Bad quality but u can hear it. Sound is coming approx 1500rpm and 5000rpm. Between its quiet. Valve to rocker clearance is ok. We start the engine without valvecover and it seems to be ok, oil is squirting etc. Only thing im thinking is those "vtec pistons" or something, that holds those pins which holds rocker arms. Is it possible install that rocker arm holding shaft 180 degrees wrong?
Fresh bore 81.5mm with SRP pistons, eagle rods and crank. ACL race bearings. Oil 10w40 semi synthetic (drive in oil)
Engine runs smoothly but sound like diesel. Help needed.
Old Jul 29, 2009 | 09:43 AM
kyden's Avatar
Default Re: Help with strange noise with built b16a2
lost motion assemblies.
you might want to find a new manifold while you're at it..
Old Jul 29, 2009 | 01:12 PM
omiehomie's Avatar
will bad LMA's make it sound like a VW or a disel car? :-O ?
Hybrid96EK
May 27, 2011 09:22 AM
the_dxB16
14
Jan 1, 2009 08:57 AM
lke2drvgsr
Dec 15, 2004 08:57 AM
NyStreet's_4life
Jul 2, 2004 07:53 AM
tegasaurus
May 23, 2004 12:21 PM
