Help! Oil Sender
Old Jun 5, 2002 | 10:55 PM
ion_four's Avatar
Default Help! Oil Sender
To make a long story short...I hooked up a line from the stock sender location, and when I turned on the car, the CEL did NOT come on, but I noticed that the wire to the sender wasn't even connected! Does the sender only put out a voltage, or make a circuit when the pressure is low? Or, is there something wrong...?
Old Jun 6, 2002 | 03:05 AM
DSF's Avatar
DSF
Default Re: Help! Oil Sender (ion_four)
The sender is nothing more than a switch. At low oil pressure (@4psi I've been told), the switch completes a circuit to ground. It has nothing to do with the CEL. I don't run the stock sender on either of my cars.
Old Jun 6, 2002 | 03:40 AM
RGAZ's Avatar
New User
Yep, that's right. You can leave the sender disconnected and it will not set a CEL. It only goes to ground if the pressure is under 4psi. You can leave it disconnected.
Randy
Old Jun 6, 2002 | 09:43 AM
ion_four's Avatar
Default Re: Help! Oil Sender (RGAZ)
Thanks guys, just want to make sure I'm not going to get myself into any trouble. I'm going to get an oil pressure gauge, so it'll be all good. I already have one, but it is a POS.
so, if I disconnected the sender from the oil line and had it still connected to the dash wire, I should get a light, correct?
I've read your site a bunch, Randy, very useful! However, I went to an oil filter/hose shop yesterday and I learned that there is a difference between BSP and BSPT fittings (ie. taper). Your parts list says you used a BSP fitting, as alot of other people have. Has it given you any trouble? I bought both and couldn't get the BSP in after a couple tries, and the BSPT just went right in. It was also only $5 for the adapter, as compared to $13 for the BSP.
[Modified by ion_four, 6:48 PM 6/6/2002]
Old Jun 6, 2002 | 09:51 AM
DSF's Avatar
DSF
Yes. But why would you do that?
Old Jun 6, 2002 | 12:26 PM
Xerxes's Avatar
New User
BSPT is definitely the one you want to use.
-Xerxes
Old Jun 6, 2002 | 11:45 PM
ion_four's Avatar
Default Re: Help! Oil Sender (DSF)
To make sure that the dash light and sender are working. Extra insurance.
Old Jun 7, 2002 | 04:16 AM
RGAZ's Avatar
New User
The site is incorrect, it should say BSPT, not BSP. I got the adapter for $5 from Autozone. Good catch. Gary did most of the work on the site. We are getting sick and tired of people asking a million newbie questions, so we haven't been updating the site recently. We are letting Jeff Frank at http://www.homemadeturbo.com deal with the mass of newbies now. He's blown up 5 engines learning about turbos, we haven't broken anything yet.
Randy
drSquish
Oct 16, 2005 02:30 PM
DOHCarp
Apr 29, 2005 04:19 PM
civicridah
Jul 17, 2003 12:09 PM
Lamchop0000
Sep 7, 2002 12:23 PM
pelotudo
Aug 18, 2002 06:31 PM
