help no boost
Old Aug 24, 2003 | 01:47 PM
blackfrohatch's Avatar
Default help no boost
i have a t3 on my 94 accord ex with a tial 38mm wastegate ,talon bov and u can hear the turbo spool and the wastegate open. but i am getting nearly no boost. like .8 to .1 bar. u can hear the bov go off but there is still hardly any boost. i got a .4 bar spring in the wastegate and the wastegate is opening at like 4 grand all the connections have been checked a million times and i am still getting nothing
please help
Old Aug 24, 2003 | 03:26 PM
turbocivicls's Avatar
Default Re: help no boost (blackfrohatch)
make sure your vacuum connections are correct - those are very easy to overlook. also.. since you're boosting so little, first gear usually won't show much boost on the boost guage. last thing i can think of is to check the turbo piping to make sure there's no leaks. hope that helps.
Old Aug 24, 2003 | 03:50 PM
gsr sol's Avatar
check your intercooler piping as well. some kits come with pretty crappy rubber elbows that can blow off
Old Aug 24, 2003 | 04:15 PM
Default Re: help no boost (gsr sol)
well i unhooked the wastegate and i got boost no problem.i had the wastegate line hooked up right next to the turbo. i think that is the problem so i am going to hook up the line near the tb so the wastegate will not open till the tb is see that boost.
there is no leaks in the ic lines. i checked a million times and the ic has no leaks that i can see or feel
Old Aug 24, 2003 | 10:59 PM
hmmm... you shouldn't have to hook it up like that. the tial wastegate has two spots where you can connect a vacuum to. make sure that the vacuum line that connects to the turbo is connected to the opening on the side of the tial wastegate and not the top. the opening on the top of the wastegate is for a boost controller.
Old Aug 26, 2003 | 06:47 AM
Default Re: help no boost (turbocivicavr)
well it is the wastegate they must of gave me the smallest spring they had. it will open with about 3 psi. i used a small compressor to open it and it oppend with 2 to 3 psi i ordered the .4 bar spring so that should be 5.88 psi should i just get a boost controller or get a new spring?
richboi
Apr 15, 2007 07:46 PM
asianspeed
Mar 1, 2006 09:34 PM
1FastCoupe
Aug 24, 2005 02:03 PM
japspec
Oct 24, 2003 07:49 PM
asianspeed
Feb 19, 2003 09:05 PM
