help! need seals for a t3t04e
Old Oct 27, 2006 | 01:10 PM
jtracing919's Avatar
Default help! need seals for a t3t04e
I have a t3o4e that has about 3000 miles on it and the seals are leaking. i dont know why they are leaking. I bought it new, always let it cool properly, my drain is fine, but it leaks and my car smokes blue when idling. I am running a straight t3 now, and have no problems. i need to find a place that sells the correct seals, its a garrett 57trim t3/04e.
Old Oct 27, 2006 | 03:39 PM
TheShodan's Avatar
Moderator
Default Re: help! need seals for a t3t04e (jtracing919)
Rebuild kits are about $110 shipped. Please let me know if you need one.
Old Oct 27, 2006 | 04:05 PM
RedEj8's Avatar
Default Re: help! need seals for a t3t04e (TheShodan)
The seals are probably bad because you need an oil restrictor.After you rebuild the turbo make sure you get one of those too.
Old Oct 27, 2006 | 08:10 PM
Default Re: help! need seals for a t3t04e (RedEj8)
i didnt have a restrictor at first, but i put one on and it still leaked so maybe that caused it.
Old Oct 27, 2006 | 08:18 PM
NJIN BUILDR's Avatar
Make sure its not the valve seals first.Pull the ex manifold off and look at the ex ports.If they are wet and oily its probably not the turbo.
Old Oct 27, 2006 | 08:27 PM
Default Re: help! need seals for a t3t04e (NJIN BUILDR)
i bought a used turbo and have been running it for about 3000 miles now and dont have any issues, and i had oil in the intercooler pipingwith the old turbo
Old Oct 29, 2006 | 01:51 PM
I'm interseted in getting a kit
Old Oct 29, 2006 | 01:59 PM
http://www.gpopshop.com/index.html
Or email/IM TheShodan
Old Oct 29, 2006 | 03:57 PM
I Have an STD's Avatar
wrenchin'
blaastperformance.com rebuilds turbos for cheap
Old Oct 30, 2006 | 06:00 PM
Default Re: help! need seals for a t3t04e (I Have an STD)
thanks!
jtracing919
Apr 17, 2008 01:31 PM
richieb18c1
Jan 29, 2008 02:52 PM
1bar_ek
Aug 15, 2005 11:21 AM
B20 BEAST
Mar 15, 2003 03:59 PM
T-sohctec
Sep 10, 2002 09:27 PM
