i think my turbos bad can anyone help me
hey guys i need help again i have a turbo b20 and it smokes when ever the motor gets hot it looks like its just comeing from the manifold but i dont know and when u rev it up nothing happens but after it comes down from the rev alot of white smoke comes out of the exhaust could it be the seals in my turbo or some dumb shyt that i did please let me know so i can buy a new one or rebuild that one thanx
Re: i think my turbos bad can anyone help me (B20 BEAST)
its most likely your seals. they are probably worn from wear and tear. how many miles on the turbo? how is your oil drain set out? sometimes if you dont have it draining properly, it will build up and blow the seals. hope that helps
you could get it rebuild
Re: i think my turbos bad can anyone help me (wickedxboi)
how much would it cost to get the seals redone i dont know much about turbo i just got it i had nitrous before so thanx for all the help is there anything else i need to know i did readjust my oil return it helped a little so i guess its my seals
i'm sure its the seals. Mine did the same thing...smoked out the exhaust when the car heated up. I got a new turbo and it fixed that.
Probably costs around $200 to get oil seals replaced unless you do it yourself which it way cheaper.
Re: i think my turbos bad can anyone help me (BoostedSi)
Re: i think my turbos bad can anyone help me (UberTeg)
http://store.yahoo.com/cheapturbo/fullrebuild.html
Full Rebuild $250 from chepaturbo.com.
"THIS INCLUDES ALL FACTORY SEALS AND BEARINGS BEING REPLACED, REBALANCING THE SHAFT AND CENTERSECTION AS WELL AS A FULL INSPECTION OF THE STATUS OF ALL OTHER COMPONENTS.ALSO INCLUDES FREE SHIPPING BACK TO THE CUSTOMER.
service can be done on all types and brands of turbochargers. (ie. IHI, Mitsubishi,Garrett...)
customer must send in their turbocharger. please allow 3-4 business days for labor to be completed.
this does not cover any damaged compressor or turbine wheels. customer will be notified if these need to be changed and damaged wheels will be returned to customer when they have been replaced with new."
Re: i think my turbos bad can anyone help me (mamaboy)
