Help, need info on Fuel system control
Old May 10, 2004 | 03:56 PM
Bseriescivic5's Avatar
Default Help, need info on Fuel system control
Ok guys, got a d16z6, going into 94 hatch. Motor is turbo VIA custom kit(14b) i am just finishing up getting all the pieces, BOV and FMU is left. So heres the question, i do not have the money for hondata/uberdata , so i want to do something cheaper, i have heard a bit about the afc hack?? but am still very much in the dark, did a serach and found nothing conclusive, and input would be greatly appriciated, thankls
Old May 10, 2004 | 04:40 PM
Joseph Davis's Avatar
Default Re: Help, need info on Fuel system control (Bseriescivic5)
Uberdata is cheaper than a used AFC.
Go back to square one, do your research.
Old May 10, 2004 | 04:57 PM
cannont use uberdata, do not have the expertise, or time to mess with it, need a daily driver, something easy to mess with and not so much in depth as uberdata is
Old May 10, 2004 | 06:25 PM
integrx's Avatar
New User
just have someone burn you a chip. Since you are already obd1
Old May 11, 2004 | 12:02 PM
really? all i need as far as a simple, but effective fuel management is a chip? my buddy has a bunch of p28, and 72 ecus that would be a easy fix
Old May 13, 2004 | 10:57 AM
any more ideas guys?
Old May 13, 2004 | 12:32 PM
FOrSfEd's Avatar
Default Re: (Bseriescivic5)
I would honestly go with something better that an fmu or an afc, cause you daily driver won't last long. Don't cheap out on the most important part. IF you have to wait and save do so, or you could be sorry in the long run. Uberdata is not that expensive at all.
Old May 13, 2004 | 12:46 PM
lgcubana's Avatar
Default Re: (FOrSfEd)
I would recommend a fuel regulator and or larger injectors. The 1st time that I turboed my D16Z6 I was running lean @8 psi. Wasn't really concerned about it since I was having a block built at the time. After installing the "New" block, I added 440 injectors, fuel reg. & a dyno tuning w/a Greddy E-manage.
Old May 13, 2004 | 02:01 PM
drvfast's Avatar
uberdata
Old May 13, 2004 | 03:59 PM
turbogeekDA6's Avatar
i agree with FOrSfEd, dont skimp on the MOST important part. the tuning/fuel management is what really makes or breaks the car. you will regret all of the money spent if you break a motor bc of bad fuel management/tuning. just get uberdata like everyone else said and have someone write you a good basemap and take it easy until you can get someone professional to tune it.
Old May 14, 2004 | 10:20 AM
sounds good guys....so what am i looking at here..... i know a bit about uberdata..its a computer program runs off your laptop, similiar to hondata, and its cheap, but from what ive read, it takes a bit to understand how to use it...
Old May 21, 2004 | 07:16 PM
so where can i go about getting uberdata?
h kid
May 7, 2005 12:09 PM
integ6657
Oct 2, 2004 02:05 PM
Acura_I-RS
Feb 16, 2003 10:05 AM
avividmemory
Aug 21, 2002 08:36 AM
dwilson
Jul 27, 2002 07:01 PM
