HELP!!! Need Bearings Colour QUICK!!!!
Old Sep 10, 2003 | 09:21 AM
T-Blaze's Avatar
Default HELP!!! Need Bearings Colour QUICK!!!!
Some1 out there must know this???
I have a B16A2 Block and I'm building it with JE Pistons and Eagle Rods... I need to know the colour of the Big End Bearings for the Eagle Rods??? Can any1 Help??
The Number on my Crank is 3311 and the Letter on the Eagle Rods is a 'C' I believe!!!
TIA
Old Sep 10, 2003 | 09:24 AM
inspyral's Avatar
If the Eagle "C" is the same as Honda's "C", then it should be brown, brown, yellow, yellow.
Old Sep 10, 2003 | 09:26 AM
Boostfed's Avatar
New User
Default Re: HELP!!! Need Bearings Colour QUICK!!!! (T-Blaze)
That should be vice versa, the carnk should have letters for the rods and the rods should have numbers. The Eagles I believe are a size 3, double check on that could be a size 2 actually. all Eagle or Endyn
Old Sep 10, 2003 | 09:38 AM
EH2LS's Avatar
Default Re: HELP!!! Need Bearings Colour QUICK!!!! (Boostfed)
how do you know what colors to use for different rods?
Old Sep 10, 2003 | 09:42 AM
inspyral's Avatar
Default Re: HELP!!! Need Bearings Colour QUICK!!!! (Response)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Response &raquo;</TD></TR><TR><TD CLASS="quote">how do you know what colors to use for different rods?
The crank has stamps that denote the size of the rod journals, and the rods themselves have numbers or letters on them to denote the size of the big end. With those two parameters, you can look up the coresponding bearing color in your Helm's manual.
Old Sep 10, 2003 | 09:51 AM
T-Blaze's Avatar
The Crank definately has numbers on it... 3311 and The Rods have C written on them. If only we got Helms manuals in the UK!!!!! I'm gonna have to fly out and get one.!!
Any1 else with the definitive answer??
Thanx Guys.
Old Sep 10, 2003 | 10:00 AM
Boostfed's Avatar
New User
Default Re: (T-Blaze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-Blaze &raquo;</TD></TR><TR><TD CLASS="quote">The Crank definately has numbers on it... 3311 and The Rods have C written on them. If only we got Helms manuals in the UK!!!!! I'm gonna have to fly out and get one.!!
Thanx Guys.</TD></TR></TABLE>
The #s then will be for the main bearings then and the Letters should be for the Rod bearings, the stock rods have a # on the side but Eagle rods do not, in your insturctions should tell you they are a size 3 I believe.
Old Sep 10, 2003 | 10:03 AM
T-Blaze's Avatar
So do I just get Big end bearings for a size 3 rod? (If that'swhat they are?) What colour would they be??
Thanx.
Old Sep 10, 2003 | 10:14 AM
inspyral's Avatar
Size 3 rod is the same as a"C" rod, at least according to the Helm's.
Kendall
14
Mar 1, 2023 07:16 PM
Bc3
Dec 26, 2006 11:35 AM
drudy
Jan 30, 2006 01:56 PM
One8Hatch
Dec 16, 2001 10:44 PM
dustin
Nov 8, 2001 02:53 PM
