help need advice on setup
I have a h23 in a delsol turbo with a gt30 sence i have a h23 the back sheep of motors in the honda world i did't not have alot of choices on a manifold. So i called sfp and got there street manifold they said it would hit the front mount but sence it was in a civic it would be ok so no big deal. So i get it and go to fit it up but the turbo is hiting the block so i grind i little of so it clears and this and now this happens i cant fit the radiator back in. If and one knows where i can get one that would fit or if there race manifold would work plz let me know any info helps out
thx alot mark
http://www.myimgs.com/data/hat...9.jpg
http://www.myimgs.com/data/hat...8.jpg
http://www.myimgs.com/data/hat...2.jpg
thx alot mark
contact some of the fabricators on the boards, i bet they'll be able to make a nice custom one for you.....there are lots of them
(tinker219, full-race, projectdc2, overblowteg...etc)
i might have to go that way but now i have this manifold i have to sale to get $$$
or some thing o and those manifold go for a good $$$ and thats a lot of over time
money
money
Hey I have a fully built h23 in a 95 eg the manifold I use is a max rev manifold I bought it for about 450 they have a web site maxrev.com I had it for over a year now it hasn't cracked yet.I had it in a 96 lude with ac/pw steering.7 mounths ago it whent in the coupe. hope that helps
I had similar problems with fitment ussues on my h23a. I went with a love-fab and if you speak with cody and give him measurements, he can make you a manifold that will better fit your set-up. The only reason I ran into problems is due to the large compressor that i run... it was hitting the radiator. So I modded the hell out of my radiator support. You might want to look into modifying your radiator supports as well and locate them a little closer to the passenger's side fender for clearance. You can also run a pusher fan and mount it on the otherside of the radiator support if you have clearance. You'll also probably need to get a slim-fit fan and wire it backwards to make it a pusher or regular to make it a puller. Post up another picture looking head-on into the bay it will allow us to see what other options you might be able to pull off.
I also take it you are not going to run a traction bar and do away with the front motor mount, right?
Here are some pictures of what I had to do to possibly help you out:
Pullig
Jan 20, 2005 07:27 PM
hatchback19
Jun 1, 2003 04:32 PM
yea i have that stuff too i will take more pic and put them up
