help need advice on setup
Old Feb 10, 2004 | 06:31 PM
delslowh23's Avatar
Default help need advice on setup
I have a h23 in a delsol turbo with a gt30 sence i have a h23 the back sheep of motors in the honda world i did't not have alot of choices on a manifold. So i called sfp and got there street manifold they said it would hit the front mount but sence it was in a civic it would be ok so no big deal. So i get it and go to fit it up but the turbo is hiting the block so i grind i little of so it clears and this and now this happens i cant fit the radiator back in. If and one knows where i can get one that would fit or if there race manifold would work plz let me know any info helps out
thx alot mark
http://www.myimgs.com/data/hat...9.jpg
http://www.myimgs.com/data/hat...8.jpg
http://www.myimgs.com/data/hat...2.jpg
Old Feb 10, 2004 | 06:40 PM
delslowh23's Avatar
Default Re: help need advice on setup (delslowh23)
i hope the pic help out
Old Feb 10, 2004 | 06:44 PM
B18Flip's Avatar
contact some of the fabricators on the boards, i bet they'll be able to make a nice custom one for you.....there are lots of them (tinker219, full-race, projectdc2, overblowteg...etc)
Old Feb 10, 2004 | 06:49 PM
delslowh23's Avatar
Default Re: help need advice on setup (B18Flip)
i might have to go that way but now i have this manifold i have to sale to get $$$
or some thing o and those manifold go for a good $$$ and thats a lot of over time money
Old Feb 10, 2004 | 07:21 PM
importboi22's Avatar
have you tried turning the turbo housing?
Old Feb 10, 2004 | 09:30 PM
VNTEC's Avatar
B A N N E D
Yeah judging the pics u can try to clock your turbo more upwards, since ur gonna be running a water to air intercooler also.
Old Feb 11, 2004 | 01:14 AM
delslowh23's Avatar
Default Re: help need advice on setup (VNTEC)
the manifold holds the turbo to close to the hood by the time i but the 90 on its in the hood. thx tho keep the ? comeing
Old Feb 11, 2004 | 01:47 AM
flip1199's Avatar
just clock it facing up. That's how most h-series guys have to do it anyways.
Old Feb 11, 2004 | 06:21 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
Hey I have a fully built h23 in a 95 eg the manifold I use is a max rev manifold I bought it for about 450 they have a web site maxrev.com I had it for over a year now it hasn't cracked yet.I had it in a 96 lude with ac/pw steering.7 mounths ago it whent in the coupe. hope that helps
Old Feb 11, 2004 | 12:56 PM
delslowh23's Avatar
Default Re: help need advice on setup (justYncredible)
cool i will think about that thx
Old Feb 11, 2004 | 04:10 PM
delslowh23's Avatar
anymore?
Old Feb 11, 2004 | 04:15 PM
spun Vtec's Avatar
i would just make new mounts for the rad. just move it over 2-3 inches to the left you will have plenty of room then.
Old Feb 12, 2004 | 01:18 PM
delslowh23's Avatar
Default Re: help need advice on setup (spun Vtec)
i tryed that but it hits the headlights
Old Feb 13, 2004 | 07:34 PM
delslowh23's Avatar
dose anyone know how much a manifold that would work?\
thx
Old Feb 13, 2004 | 10:44 PM
PrecisionH23a's Avatar
I had similar problems with fitment ussues on my h23a. I went with a love-fab and if you speak with cody and give him measurements, he can make you a manifold that will better fit your set-up. The only reason I ran into problems is due to the large compressor that i run... it was hitting the radiator. So I modded the hell out of my radiator support. You might want to look into modifying your radiator supports as well and locate them a little closer to the passenger's side fender for clearance. You can also run a pusher fan and mount it on the otherside of the radiator support if you have clearance. You'll also probably need to get a slim-fit fan and wire it backwards to make it a pusher or regular to make it a puller. Post up another picture looking head-on into the bay it will allow us to see what other options you might be able to pull off.
I also take it you are not going to run a traction bar and do away with the front motor mount, right?
Here are some pictures of what I had to do to possibly help you out:
Old Feb 14, 2004 | 06:38 AM
delslowh23's Avatar
Default Re: help need advice on setup (PrecisionH23a)
you are a mind reader yea i have that stuff too i will take more pic and put them up
thx alot
Old Feb 14, 2004 | 06:46 AM
delslowh23's Avatar
o yea it looks very nice
Old Feb 14, 2004 | 03:32 PM
spun Vtec's Avatar
i hope your not driveing that car like that... with no filter on the turbo one stone chip and bye bye comperssor wheel.
Old Feb 14, 2004 | 04:00 PM
Usually I run the turbo with a wire-mesh screen over it. I do have a filter pipe I run on occasions.
allentownrep
Jun 6, 2007 05:08 PM
delslowh23
Apr 8, 2005 06:39 PM
Pullig
Jan 20, 2005 07:27 PM
hatchback19
Jun 1, 2003 04:32 PM
